Mk1 Resto
206 replies to this topic
#16 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 23 October 2012 - 08:05 AM
Ordered all the panels from M-Machine.
Had time to pull one door apart yesterday. The bottom was a little bit rotten -
New bit in -
Just need the door skins & all the other panels to come now.
#17 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 01 November 2012 - 01:52 PM
Panels have arrived :) Got the door skins on -
While I was waiting for the panels & stripped the engine down. I am waiting for new mains & big ends. The oil pressure was quite low on warm idle so hopefully these & a new oil pump will sort it.
It was also in bad need of new stem seals so I stripped the head, cleaned everything up, lapped the valves in, new stem seals.
#18 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 04 November 2012 - 01:28 PM
Got the flitch done & the A panel on -
#19 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 07 November 2012 - 09:51 PM
Wing on & n/s floor & sill tacked in -
#20 minimikej
minimikej
  • 347 posts
Posted 07 November 2012 - 11:23 PM
Was wondering, what are those two 'buttons' above the top hinge mount?
Great progress and tidy work
#21 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 08 November 2012 - 08:28 AM
I think I know what you mean, they're just plug welds that I hadn't cleaned off when I took the picture.
#22 SAL 821X
SAL 821X
  • 1,890 posts
Posted 09 November 2012 - 01:21 PM
Hi Josh just found this thread, some cracking work so far, I'm about to tackle the door skins on the van any tips? ;)
I also just remember I emailed you about some parts weeks and weeks ago for the van.
will let you know about that in due course.
Looking forward to your next update.
#23 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 09 November 2012 - 01:47 PM
Hello there, I have a piece of wood, a length of roofing baton that I clamp the skin to the frame with along the bottom as the door has a slight outwards curve to it. It just holds it in place nicely along with a pair of molegrips at each top corner while you go around folding it over. Hope that makes some sense!
#24 gs.davies
gs.davies
  • 60 posts
  • Local Club: Essex Mini Club
Posted 09 November 2012 - 03:26 PM
Nice - is the sill and floor section the M-Machine panel that has the outer sill already attached? Was it easy to fit?
#25 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 09 November 2012 - 04:54 PM
Yep tis M-machine with outer sill, it's a pretty good fit, took a bit of bashing & bending but that's probably more due to my shell than the new panel!
#26 leadly
leadly
  • 779 posts
  • Local Club: [] D.C.M.O.C []
Posted 09 November 2012 - 05:48 PM
Looks brilliant, can't wait to see more graft happening!
#27 gs.davies
gs.davies
  • 60 posts
Posted 09 November 2012 - 06:03 PM
Have you taken the bottom on the rear bin off to help with fitting that up as well?
#28 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 09 November 2012 - 06:45 PM
Thanks, good to know someone is interested :)
Yeah the bottoms of the rear bins were all patched up & horrible, lower bin repair panels are cheap enough from M-Machine & it makes fitting the floors much easier.
#29 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 11 November 2012 - 06:22 PM
All welded, bit more cleaning up to do but nearly one side done which is nice -
#30 RawlinsGTR
RawlinsGTR
    Formally known as Dog
  • 1,046 posts
Posted 11 November 2012 - 06:23 PM
Looks pro Josh :)
Coming along pretty quickly.
