8 Port Supercharged With Double Twin Webbers?
47 replies to this topic
#46 Wil_h
Wil_h
  • 3,244 posts
Posted 18 November 2012 - 02:07 PM
The size of the valves per-se is not the issue, it's the amount of material left between them in the head. the extra heat of the charged burn can lead to heads cracking.
I'm doing the harewood championship in 2013, so I'll be there lots. Might do an Olivers Mount too.
#47 mini13
mini13
  • 3,811 posts
Posted 18 November 2012 - 04:16 PM
37mm inlets and 31mm exhausts are what I run,
on the 7 port heads the valves a bit further apart so your in a better position to run valves of this size.
#48 boonas
boonas
  • 27 posts
Posted 18 November 2012 - 05:26 PM
the tipo of my weber are 40dcoe151. can i use it for blowthrough supercharging?
