Supercharged Photo Album
Posted 17 November 2012 - 11:10 PM
And any modifications to improve the suck through kits like having copper pipe on the inlet
Posted 19 November 2012 - 04:18 PM
Here is my Vmax Scart built engine and sc, also fitted Mega Jolt using MED's pulley and pickup. Still running it in, but would be keen to see what I can do about the intake pipe / carb freezing up! The head is an SPI and so both heater hoses are on the rad side of engine, I would like to use the regular heater take off on the transfer case side of engine and do something with copper pipe. Or I could use some form of electic heater in the air filter.
Posted 19 November 2012 - 04:37 PM
sc.jpg 68.17K 303 downloads
Vmax do a carb heater kit - how do you find your setup? Im considering one as a winter project :)
Posted 19 November 2012 - 10:38 PM
Sorry about the 3rd picture, can't seem to remove it!!
Edited by Grahamxx, 19 November 2012 - 10:42 PM.
Posted 20 November 2012 - 01:37 AM
I'm going to try the copper pipe idea as I can't weld
But I was thinking of wrapping the copper pipe withe exhaust wrap to keep the heat it better
Posted 20 November 2012 - 10:43 AM
Posted 20 November 2012 - 04:15 PM
I am well happy with it though! It did stop the other morning when it was very early, 5am, freezing and a bit foggy. It was probably 2nd time in use in anger, eventually limped it home, but since then its never done it at all, but also I have not taken it out in such cold / misty conditions so there could be a pattern! Not sure what the actual issue was though.
Posted 21 November 2012 - 06:19 PM
Here's mine:
I added a little enclosed heating element into the air filter and mounted a switch under the dash. Works really well, never had any problems with the throat of the carb icing up since fitting it.
Cheers,
Jon.
Posted 21 November 2012 - 08:26 PM
Posted 21 November 2012 - 10:12 PM
Edited by Rusty1182, 21 November 2012 - 10:13 PM.
Posted 22 November 2012 - 09:33 AM
Posted 22 November 2012 - 12:43 PM
Edited by Gr4h4m, 22 November 2012 - 12:44 PM.
Posted 22 November 2012 - 01:19 PM
http://www.halfords....tegoryId_255221
Its supposed to absorb water in the fuel system.
Posted 22 November 2012 - 05:57 PM
He used something that looked exactly the same as this.
Neat and tidy and worked very well.
http://www.ebay.co.uk/itm/MORRIS-MINOR-DASH-POT-HEATER-/380521112394?pt=Motors_Car_Truck_Parts_Accessories&hash=item5898d3634a
Posted 22 November 2012 - 07:58 PM
It was an enclosed heating element from RS Components. I can't remember the exact model number but I'm sure a search on here would help find it. I'll have a look otherwise.
Yeah it is, it developed a small air leak from a small gap in the weld of one of the intake runners. I bought a length of steel bar from B & Q and made this (and sprayed it silver). All the force from the supercharger was just being held by the welds and the manifold studs. It just helps spread the load.
Cheers,
Jon.
5 user(s) are reading this topic
0 members, 5 guests, 0 anonymous users
