Supercharged Photo Album
#16
Posted 22 November 2012 - 09:31 PM
#17
Posted 23 November 2012 - 12:03 PM
#19
Posted 23 November 2012 - 05:44 PM
Did you fuse the small heater? I bought a 15 watt 80degrees one. Running 12 volts, this is less than 2amps? Is it worth it to fuse it?
Yeah I did, I put in a fuse on the positive line. I think that's the same element as I have off the top of my head. Considering it is running near fuel, it's really important it's fused even though the current is fairly low, otherwise if there was a problem with the heating element or a wire sparked, it could potentially cause a small fire/explosion within the air filter.
If you are planning on drilling a hole in the back of the filter housing for the wires it's also worth getting a little rubber gromet to fit in the hole. This will prevent the wires from chafing on the sharp edge left by the drill.
Hope this helps.
Cheers,
Jon.
#20
Posted 25 November 2012 - 06:59 PM
#21
Posted 29 November 2012 - 07:39 PM
I've warped copper pipe around the inlet pipe but I've also wrapped it with exhaust wrap to try keep the heat in
Edited by Rusty1182, 29 November 2012 - 07:40 PM.
#22
Posted 05 March 2013 - 08:34 PM
Ok we'll I've just fitted my supercharger and I've decided to try something out
I've warped copper pipe around the inlet pipe but I've also wrapped it with exhaust wrap to try keep the heat inimage.jpg 50.75K 155 downloads
Hi, what size copper did you use and how is it running?
#23
Posted 06 March 2013 - 09:20 AM
Edited by Nick Warwick, 06 March 2013 - 09:20 AM.
#24
Posted 06 March 2013 - 09:32 AM
I used 8mm micro bore of ebay to wrap mine then plumbed it into the cooling system.
Does it work well
#25
Posted 06 March 2013 - 08:22 PM
#26
Posted 06 March 2013 - 09:03 PM
Yeah worked well for me, i also had a heating element in the air filter.
yeah, i've got the heater element, but in my initial testing after rebuild, I'm getting fuel coming out of the air filter after engine is turned off. Granted, it's not after a run but making adjustments whilst sitting in the garage.
#27
Posted 07 March 2013 - 01:08 PM
Found by putting a water jacket round the pipe transformed the driving totally, no hesitation, smoother and no icing up
Graham, I had one of your intercoolers on my Escort RS turbo and it was superb! I love this, and would love it on my mini!
#29
Posted 13 August 2013 - 02:27 PM
Already done
It does work well though
#30
Posted 14 August 2013 - 08:35 PM
Edited by si-supercharger, 04 December 2013 - 08:43 PM.
