Crayford Convertible In For Restoration @ Mintec
118 replies to this topic
#61 MrBounce
MrBounce
  • 2,661 posts
Posted 13 March 2013 - 11:01 PM
Absolutely amazing! Love love love it! :wub: :mrcool:
#62 mk1leg
mk1leg
  • 9,343 posts
Posted 16 March 2013 - 08:51 PM
great progress your a skillfull man......... :proud:
#63 Tupers
Tupers
  • 4,156 posts
Posted 17 March 2013 - 10:09 PM
love this build lovely work !
Thanks guys I do enjoy turning out good work and I'm glad you're all enjoying it. :highfive:
The new flitches arrived this week and I set about modifying them to correct MK1 spec.
As they're based on late van pressings they have indents for MK3 air vents and wiper motor recess that need removing.
After cutting the lumps and bumps out I did a little gentle shaping and got the new section tacked in.
Then it was just a case of slowly welding between the tacks to avoid distortion and linishing down the seam.
#64 Tupers
Tupers
  • 4,156 posts
Posted 21 March 2013 - 09:18 PM
I got the second flitch smoothed out this afternoon in between fitting floors into a '68 Hornet .
All chopped out.
Nice new contoured pieces flushed in.
Once it was all done Jon bolted the front end up while I carried on welding the floors into the Hornet.
After all that was done Dad cleaned up and re-bushed a set of hinges and we got the O/S A-panel welded on. (Wing had already been lined up then removed for better access)
#65 Tupers
Tupers
  • 4,156 posts
Posted 25 March 2013 - 11:37 PM
So dad's been pressing on with the Crayford and It's now all but ready for the wings and front panel to be fitted.
The original rad cowl has been plug welded onto the new flitch but we chose to braze the commission number on from the back and at the same angle as the original to keep it looking factory.
Dad also saved the NMP tag from the front panel and brazed it onto the new one.
While he was at it he replaced the latter number plate brackets with the MK1 versions and added the tea strainer for the heater intake.
And last but not least all of the welds inside the flitches have been linished down and the whole lot zinced and primed as well as the inside of the wings.
#66 hughJ
hughJ
    Soldiering Along
  • 727 posts
Posted 27 March 2013 - 09:24 PM
My word that is some skilled work. Even looking at the lie of the bonnet along the inner wing. Sure wish I'd done mine better. Thanks for showing how it should be done!
Hugh
#67 mk1leg
mk1leg
  • 9,343 posts
Posted 05 April 2013 - 08:22 PM
now is that you and your clubman in this months mag............ :proud:
#68 CobraV8
CobraV8
  • 991 posts
Posted 06 April 2013 - 03:37 AM
It is impressive looking at your work, and shows just how much work there is to do it right. Any idea of the total hours it will take?
#69 CLM
CLM
  • 817 posts
Posted 06 April 2013 - 03:44 AM
Since you are going through all the work, any thoughts to replacing the larger late front turn signal plinths with earlier ones pulled from a donor panel?
Your work is definitely beautiful by the way :)
Chris
#70 Tupers
Tupers
  • 4,156 posts
Posted 06 April 2013 - 05:12 PM
Hugh
Thanks Hugh it takes a little time to get everything pointing in the same direction but it's worth it in the end.
It is indeed awkward poses and all. :lol:
There's around 180 hours in the metal work so far and probably that much again to get on the road.
Chris
Don't fear we'll be replacing those and also fitting the correct rounded valance corners.
#71 mk1leg
mk1leg
  • 9,343 posts
Posted 06 April 2013 - 07:44 PM
ah good.....have you a build thread for the clubman.......aswell...... :proud:
#72 okc78
okc78
  • 169 posts
  • Local Club: none so far
Posted 06 April 2013 - 11:07 PM
Thanks for taking the time to post your progress, a fantastic job your doing there and its really helping me with the bodywork of my mkII. Did you use heritage inner/outer A panels or patern for this car? Have you any experience of the pattern ones? I'd like to use them as there so much cheaper, I don't mind a little re-shaping but wont bother if they simply don't fit, what do you think?
#73 rally515
rally515
  • 3,848 posts
Posted 06 April 2013 - 11:12 PM
I,ve bought these inners for my project & at first sight or line up with the outer there crap as the seam stip part which spot weld them to the wing seem strip is all bend & wavy due to it being pressed, but once you hammer & dolly it right they line up well together.
As for car fitment i cant see how they could be bad to be honest.
#74 Tupers
Tupers
  • 4,156 posts
Posted 07 April 2013 - 01:04 PM
I do indeed, it's only 39 pages shouldn't take you long to read. :P Clicky
The outer A-panels are Heritage and the inners are pattern from Mini Spares. Clicky
They went together very well, all we had to was punch holes in them and trim down the section that connects to the outer sill as it was a little long.
#75 okc78
okc78
  • 169 posts
Posted 08 April 2013 - 07:07 PM
Thanks for the advice, I'll go with the mini spares inner pattern ones then.
