92 Mini City
285 replies to this topic
#61 Marco1972
Marco1972
  • 822 posts
Posted 26 July 2014 - 07:43 PM
Cheers mate
Ive got the other companion bin to do as well got a slightly different approach to this one as I fitted two new ones to the lads car and have learnt from my mistakes :-) mainly the seat base lip is very thin so I'll be cutting out the bin and grinding off the spot welds from the back leaving the lip intact instead of trying to drill out spotwelds from the front
Cheers Mark
#62 Marco1972
Marco1972
  • 822 posts
Posted 20 August 2014 - 07:48 PM
Well now the lads car is almost finished ( well the metal work side of it ) it's time to crack back on with my little project
Jay looking pleased with himself :-)
4057E6ED-886A-470F-89B2-60D1ED7C3A40_zps
B499F234-9A30-4183-B15A-64CD9C093B5C_zps
Just the final few bits to do on the lads car now, it's been 8 months of graft blood sweat and tears but it's off to paint this Saturday
Just got to put it back together. :-)
I'm replacing the inner sill and as the companion bin had gone at the bottom I've decided to replace it this will allow good access to the inner sill and stiffener
Started by drilling out the spot welds along the door frame and floor
C7CF3B2A-19DC-4828-B831-A1E00BF9254A_zps
0F7B1B4C-61D8-4CB7-B329-8055224CD375_zps
Then I removed the ones from the heel board
C00D4AF8-C65D-4ECB-BCAA-16E36669E0D7_zps
Then after a quick session with the grinder out it came just had a little battle with a cheeky seam weld that the good folk at Rover had hidden where it joined to the wheel arch !!!!!
5025DED9-7223-44AA-9ACD-7AC6A2B79CC7_zps
After drilling a few more spot welds I removed what was left of the inner sill where it attaches to the inner sill stiffener so left with a nice big hole now. :-)
C2C37378-664B-4786-96A1-2FF796ADB68B_zps
Just got to remove what's left of the bin where it joins to the seat pan but I'm going to flap that off from the back leaving the lip intact this will make for a nice neat job when I weld the new new bin back in.
Finally just removed the seat belt anchor as the M Machine bin doesn't come with it that will be fitted to the new bin when I get round to it.
C2073AE2-429D-4B0A-A0EC-5BD9050EF2DB_zps
Next job is to chop out the inner sill
Mark.
#63 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 21 August 2014 - 05:45 AM
Nice work there :)
#64 Marco1972
Marco1972
  • 822 posts
Posted 22 August 2014 - 06:42 PM
Thanks mate ...
Jays cars off to the paint shop tomorrow so I'll have time to really knuckle down and get it finished
#65 Marco1972
Marco1972
  • 822 posts
Posted 31 August 2014 - 09:21 PM
Well it's pay back time after grafting for 8 months on the lads car it was time for me to get my own back :-)
Jay drilling out spot welds
E2AB08F7-D9C5-4040-91C9-3D29B068A8E3_zps
9913A933-A90C-469F-8338-64FDB7C35F7C_zps
I knew I'd have some use for kids one day ha ha
All the spot welds drilled out of the door step and inner sill
EE4E00E6-B880-463D-B960-CB0480686543_zps
93A791CE-079F-4CDD-9ED5-9076B2F14CF3_zps
Chopped out the old inner sill and jacking point
ABC90CAF-A7AF-416A-9F2E-3149413C3FCC_zps
A199A54F-30EF-4857-9524-5E9B7D39307F_zps
I was really surprised how good it was inside the cross member not a spot of rust inside
F90EC2C3-56FB-4C6A-883B-84DBFCDDB933_zps
F0785D2C-E4DE-4C73-B4DB-FF831F710E8F_zps
Tidied up the edges with the flap disc and then trial fitted the new inner sill which is an M Machine panel
64DF5C75-34A7-4224-8F16-99C0A253553A_zps
A7FF1800-E154-490A-84AB-879F8041012C_zps
Wasn't a bad fit so marked up the floor and trimmed off the excess ,after a bit of hammer and dolly work and a bit of grinding it went into place.
Couple of pics after I held it in place with inter-grips
25FE789F-C8B2-42C3-A12B-3BD54399666F_zps
F03990FA-5921-45BD-A496-3C78693D29A3_zps
It will come back out in the week as I've got to give it a coat of zinc primer
The lower part of the flitch will need replacing as it's a bit crusty and I will have to chop out the closing panel by the rear wheel arch before I weld the floor in
Plenty left to do :-)
#66 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 31 August 2014 - 09:46 PM
Bet Jay is loving going back to the manual work again!
Cracking job on the inner sill. Can you remind me, how much is that panel? I need to order one next week as my project is going to get a massive kick up the backside after all this time. I want to get the O/S done and dusted.
Ben
#67 Marco1972
Marco1972
  • 822 posts
Posted 01 September 2014 - 06:01 AM
Hi Ben
He loves doing all that stuff :-)
There £27 but you get 10% off if your a mini forum plus member mate
Cheers Mark
#68 Tricey
Tricey
  • 21 posts
Posted 13 September 2014 - 05:34 PM
Hi Mark, loving the work you've done so far. Define toy going to be following this post. I'm just in the process of starting my first mini project which involves heel boards, doorsteps and all sills. So liking the look of yours as a idea of where to start. Is that jacking point just welded to the out side of the inner sill? Cheer Adam
#69 Marco1972
Marco1972
  • 822 posts
Posted 14 September 2014 - 08:00 PM
Cheers Adam
Yes the jacking point welds straight on the inner sill, it also it attached to the outer sill ( when I fit it ) this will be going on next weekend so keep watching.
Anyway I've been able to spend some time on the car this week grabbing the odd couple of hours after work so the inner sill got a coat of zinc primer and I removed some of the bitumen so it looks tidy and will not get in the way and melt when I weld it in
385AFC2B-2CC2-4642-9934-E4F3B37DB8E6_zps
5A7C001B-EA46-43BA-A831-05CA9309A160_zps
Your probably wondering why I haven't removed all the sound proofing well the rest of the floor is
Mint and I want to keep as much of the originality as I can so that's the reason for that
I removed the old heel board closing panel along with the inner sill stiffener unfortunately one end of the stiffener is badly corroded but I think in going to repair it.
C444183D-91C1-46B5-8F70-FE61935D9284_zps
885CDB2D-3E50-4A14-85B4-641ACA120A02_zps
Then it was onto the heel board
1C3EB9E6-BA67-49C5-8747-7D8D8B59C981_zps
6F463F72-D6C6-4ED3-8509-3E6E6C669C80_zps
After a bit of trimming
F0A3C624-8027-41F1-8C31-2E327D3E05A6_zps
3D7734D3-6346-4D1F-8942-D222C89F6CB6_zps
7C105AB7-B997-4B93-B15A-1EE3FB55C038_zps
3E7F852E-4FE4-499E-9A79-B106B2D8D311_zps
I found some rust in this area so I opened up the seam cleaned it out and gave it a good coat of zinc
All welded in and ground down
8BC48274-B039-4F73-AB78-03D968032584_zps
At this point I refitted the inner sill and test fitted the subframe glad to say it fits well
8EE7BF47-607F-450F-9CB6-77218E59E445_zps
Started by tacking it all in then fully welded it up
57932251-878A-4C99-A489-B5D977483D78_zps
C9EB937E-6D0D-440E-BB20-B9AA8FEDBF1A_zps
D91DD389-F7A8-4DDA-B8DD-BC2B5C0CAD42_zps
F6CC02EA-D776-4C07-9ECB-70E20C0AF5F7_zps
Looking a bit better than before :-)
242FF287-7350-4521-90CA-075961D4A993_zps
That's it for now
Cheers for looking in
Mark
#70 Marco1972
Marco1972
  • 822 posts
Posted 11 January 2016 - 08:10 PM
Hi folks thought it was about time I updated this thread
It's been over 12 months since my last post and a lot has happened
The mini has been moved to a secure garage after the local detritus took an interest in it and decided to make my car cover into confetti
Needless to say I was far from impressed so off it went to a safe location where I can work on it in peace
I'll let the pics do the talking
EF5DD2E0-9D31-4F62-BCA1-93B4CCEE43F6_zps
Here it is in its new temporary home
Jay getting his hands dirty
03D544DA-767C-4372-8AE0-FC0C536013F7_zps
Removed the battery box quite easy as it was only held in with sealer !! Yes it was a new one on me too !!
C162E6D8-F35D-436E-9415-42A6EF0399C4_zps
D9591C09-245A-4E34-8EBE-AD7A8483BB2F_zps
EFD5978D-856F-45A4-8934-09E84203A79C_zps
Not a weld in sight !!
Cleaned it up and replaced the worst bits with fresh steel
BFBEE6C9-B7E2-44E7-B432-6AC13101E2D5_zps
A2E5522E-66DF-471A-B3A6-D8D62E4318FF_zps
1E146F02-60FC-4D0D-97EF-36C763F4350D_zps
New genuine battery box fitted
363685C8-7683-4A4A-A746-9DA6E7831D58_zps
Then it was onto the rest of the boot floor
Rot chopped out and repaired bit more finishing to do but happy with it so it got a splash of zink primer
6C61AA27-8112-45C5-A653-71E3D5805439_zps
917673C7-7EE4-4990-8A0E-B1F2CE83AC9F_zps
D7BD573E-2E90-4AB6-A21F-2D478139097D_zps
1EC84437-7476-4E76-BB33-7DA1216ADE78_zps
FE7450FD-A6A8-4AFA-8878-798DD6A57DCD_zps
C62460DC-92B5-46F8-BABB-6A0A46B76A7A_zps
This small hole was just enlarged with my burr and I welded it up and ground it down flush
E2107896-5385-455D-8194-4E8E75F4EF65_zps
066BC88E-6BE6-4947-AC76-D6CD930C3C3C_zps
Then it was onto the other boot floor corner and closing panels
1A500510-F00A-4F0E-8CBD-7780E9A94048_zps
2EB9DF01-2498-4DE8-B1EB-347D980E8B46_zps
092D7F31-B410-449D-85AD-3EC05577596B_zps
Lip replaced
467DF248-FF5F-4F48-A291-B31DBA994EA9_zps
5329E55F-8FD1-4D41-8D6F-30E0998F3AAC_zps
0870DFA8-778B-42D5-B144-C5633D52594A_zps
F20869B3-7D45-4997-A234-DF7C54004747_zps
6CBB0F8E-E6A5-4C23-8135-5CA4987710D7_zps
B5453471-84E9-4EB2-8E04-CDB193C554FF_zps
2C9D919C-4A0A-4194-A278-CEC0D2540AE4_zps
Same for the other side
B3655B4E-5BA0-48CA-BE90-509B0A546571_zps
FD27F605-223F-4DBE-BA97-2FD517DF4F7A_zps
Repaired the hole in the wheel arch
B727B5B3-E8CE-4A85-B4F8-474F4E370F6E_zps
Sealed the boot and battery box
E982AAED-D47B-41F8-A8B7-A241ED179321_zps
983E3FD0-E207-4592-84AF-917E9FF125E1_zps
Fitted the strengthening brackets
053CAAD1-CB04-4669-A446-9C8776E9D2FD_zps
Then sealed all the rear valance closing panels up
6B8C5BE5-FE70-4337-BBB7-6A0F98240DE1_zps
A9E532BC-69A4-4246-9FB3-2C65115B16FF_zps
80C2275B-8FF2-4788-9FC5-C435B3AD28D5_zps
C5BB61E4-FC96-4996-B89C-0088648D6987_zps
Test fitted the valance and it was pretty good
Yes I'm impressed with a magnum panel first time for everything :-)
So holes drilled and on it went
49B17901-E620-45F3-884B-EB5C914FADED_zps
Just had to refit the tank bracket and that was the boot sorted
The car was then turned round so I could start on the jobs on the other side
Quite a long list of things to do these were replace top dash rail,new door step,jacking point,rear quarter corner repair, front floor / wheel arch repair, companion bin,inner sill strengthening plate ,closing panels,rear wheel arch repair and new outer sill oh and I've got 2 door skins to replace too :-)
Mark
#71 Marco1972
Marco1972
  • 822 posts
Posted 12 January 2016 - 08:40 AM
Right then
The car was turned around and I removed the top dash rail it had been ( bodged) repaired previously
I replaced it with a genuine one
9D9A4687-EEFB-436B-925E-C5A92952A9A1_zps
36D9EA67-CE58-4224-8897-C59781B6008B_zps
C735D044-821B-4E04-96CE-2FAF73B110D2_zps
B6C1C3C0-AB08-4DC1-9EE1-CDF21A9C40CB_zps
768B5971-7F07-4F21-AD85-5986F8EADA24_zps
86C32A1A-2D50-48C1-AF4E-EA60048A4B18_zps
Old one out and holes drilled for the plug welds
86A9E177-EC00-404B-85F9-04FF6A68EE11_zps
55BCEA85-EAFD-485E-95A0-8E36632FFE35_zps
15C0F9D0-7E1B-4F1F-9618-AAF677D18491_zps
The scuttle had been replaced previously when the car had had its last half arsed resto by the old owner so to avoid distortion I used frost cold front and it worked very well
1BB3B89C-EA11-4566-9445-BC02EFE99040_zps
317C6D96-3DDA-41D1-A969-AF1D63562642_zps
With that done Jay ground down the welds flush and I splashed zink primer over it
C3519753-E810-4D6B-A089-A778DDA3E1E5_zps
Then it was onto the door step.
Mark.
Edited by Marco1972, 12 January 2016 - 08:42 AM.
#72 Marco1972
Marco1972
  • 822 posts
Posted 12 January 2016 - 09:48 AM
So ..... Onto the door step repair
Firstly I braced the body to avoid any movement and removed the old step I had a couple of steps from a chap off this forum ( sonic ) and I have to say that they are an exellent fit and quality
F68CE6B8-54F4-407D-8562-DC908D8AE2F8_zps
42B90356-021E-4FC9-B4E9-F45BA953B3A9_zps
5B9CD1DC-AF13-4FF5-AE40-90D599D00366_zps
This just left a small repair to the door post
C82AB670-6910-41B1-87E3-ED421AC19925_zps
F1B6A0BD-EA22-48AF-9597-8377DEED49D1_zps
BD9B4ACF-3398-47B5-92DB-C82F4C5F4B5E_zps
A61EE0FE-0F39-43C1-A940-629EC7160131_zps
With that finished I moved on to the rear quarter repair
Here's the finished job I used an MMachine panel here as they are very good fit and quality
3FFF8992-9B03-4259-ACEC-AE46351C9A21_zps
With that done it was back to the front end and off came the A Panel the lip behind had seen better days so I sorted that and gave it a splash of zink followed by a quick test fit of the new genuine A panel
425923B2-98B8-4AC9-88C8-1305A4B04062_zps
F6493667-27EE-4080-A249-6C420E2D9743_zps
D7E78985-53E4-469F-9FD8-B41851BCB408_zps
ECF6E3C6-150D-486C-ADA5-0B6E06575C33_zps
Happy with that I moved onto the new jacking point
It was seam welded on for strength and then I gave the whole area a good few coats of primer and paint
The cavity will be given a good coat of wax after I've put the outer sill on
F5212BAE-1C16-4DE9-8D8F-3F11D0817B43_zps
8C71A187-5C00-462C-B609-2D959A89FDF6_zps
C1D33BDC-1FC7-4C4D-B938-5D9AD4A024F7_zps
Mark.
#73 Marco1972
Marco1972
  • 822 posts
Posted 12 January 2016 - 01:47 PM
Right then
With that lot done it was onto the companion bin and surrounding structures
Fitted the seat belt mount to the bin as it was a M Machine panel and they don't come fitted
With that done it had a few coats of primer and paint
246CB461-1DD3-4AA3-8A6C-66276FAD3681_zps
887AF7D0-4C5E-4B74-8B19-E1BAFA881FEF_zps
5E1BD1A7-3EB6-49E8-B1A5-386A9547ED79_zps
E706E16A-E72E-4212-98BF-72F106668329_zps
5BD8A018-2953-4929-9734-63EE9FFABF5A_zps
9C484C8B-648E-4661-B057-F3BE11E2A3CE_zps
Holes drilled and then welded in
Couple of fuzzy pics inside the bin I'd welded in the closing plate and inner sill stiffener at this point and given it all a coat of paint
56CE6E48-88BC-450E-97DF-6F526D6E28BF_zps
09A8FB38-2591-4FC1-BFD4-B9004106B3DA_zps
6E5559C5-C5C0-4A89-9F37-5AE52B35F05D_zps
I've had this hole waiting to be sorted for ages so fabricated a repair panel and welded it in ground down and a splash of zink
233EE35F-6B02-4F29-8D5C-087DE3207E58_zps
3B8D5BF0-96DE-4346-B14F-9E41752650A9_zps
Next job to tackle is the front lower wheel arch you can see it was pretty crusty
0B676869-E96B-4B0D-9016-98154BF1D5D4_zps
Mark.
#74 minimissions
minimissions
  • 3,427 posts
Posted 12 January 2016 - 02:00 PM
Wow just seen this thread it looks great some really nice tidy work there :)
#75 Marco1972
Marco1972
  • 822 posts
Posted 12 January 2016 - 07:04 PM
Thanks mate
Getting there eventually I've really got my finger out over the past few weeks I want it finished for the summer
Mark
