No Oil, No Water, Down On Power, Lots Of Smoke, Engine Running On...help
73 replies to this topic
#61 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 11 March 2013 - 02:00 PM
drop a 2nd hand engine in your car mate, can be done in a day from start to finish.
#62 conlad
conlad
    Previously known as ct16mini.
  • 2,054 posts
  • Local Club: Hilltop Minis
Posted 11 March 2013 - 04:49 PM
I thought sod it and poured maybe 0.75 litres of oil in...
...looked underneath the car.....
Oil pouring out the bottom of the engine somewhere...
And its not the gear selector seal thats for sure haha
Edited by conlad, 11 March 2013 - 04:50 PM.
#63 booton
booton
  • 913 posts
Posted 11 March 2013 - 05:09 PM
is there a crack in the diff case?
is the leak in rear middle, right,left,
#64 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 11 March 2013 - 05:22 PM
Well that would explain the loss of oil and subsequent loss of oil pressure.
#65 conlad
conlad
  • 2,054 posts
Middle I'd say
Engine swap time!
#66 booton
booton
  • 913 posts
Posted 11 March 2013 - 06:09 PM
if you have the time to check it out and fix the leak then have a good look at the engine first.
the engine could be fine could be no good. but untill you have a good look there no real way other than guessing. which everyone is.
if you have not got time and you know of a good running engine then swap it.
but be care full you could end up buying an engine thats just as bad or worse,
if you can buy an engine u can see running.then good. promises and shoulds don;t mean alot.
if you change the engine and then find out later the engine is fine you could always sell it one spares for 100 quid.
#67 conlad
conlad
  • 2,054 posts
Posted 11 March 2013 - 06:12 PM
Food for thought mate for sure...
For now I'd rather swap it... as this 998 I can buy has a good head and runs well @ 55 bhp.. I know the lad who I'm buying it off and any issues I can be round his house in 2 minutes, no doubts there ;D
I like the spares idea... Always a way to make a bit of money back
#68 booton
booton
  • 913 posts
Posted 11 March 2013 - 06:14 PM
if you know its a good engine then i personal would swap it.
a garage would do the same. they won;t want to be farting about with it
a little project to strip it down have a good look after its out
Edited by booton, 11 March 2013 - 06:15 PM.
#69 conlad
conlad
  • 2,054 posts
Posted 11 March 2013 - 06:26 PM
Very true...
I could learn a lot too... Maybe not so bad after all :)
#70 grahama
grahama
  • 2,442 posts
Posted 11 March 2013 - 08:29 PM
Just to add my bit, I stripped down and refreshed my engine during my on going build. It was probably the most enjoyable bit so far and it was my first ever engine work. Very glad I did it and as you say, you will learn loads. Keep an eye out on fleabay for a bargain to shove in while you do it !!
Graham
#71 conlad
conlad
  • 2,054 posts
Posted 11 March 2013 - 08:31 PM
Graham
Cheers Graham! As I say a lad has a 55bhp 998 down the road sitting in his garage so hopefully collecting that later this week! A rebuild on that knackered one I have will be cool!
#72 jaydee
jaydee
  • 8,565 posts
Posted 11 March 2013 - 08:38 PM
Check you pot joints conditions you might need new one if oil is leaking from there.
#73 Da11yn
Da11yn
  • 72 posts
Posted 11 March 2013 - 09:55 PM
Most likely your engine won't be in tip top shape, especially as by your latter posts suggests there was absolutely no oil in it, but to look on the positive side, I have found the a series to be surprising resilient.
Had one situation where I was loosing oil pressure slowly on the motorway so to compensate I drove faster to increase the revs got to the point where i was only making 20 psi at 4000. 5 psi at idle. Pulled over oil level was fine, no obvious leaks, was planning on rebuilding the engine anyway and didn't want to wait for the AA, so drove the remaining 10 miles, by the time i got back oil light on, oil pressure gauge at zero unless 3000 plus rpm. Had resigned to the fact it was scrap, but was impressed she'd made it back. Thought i'd drop the oil see what state it was in, but nothing too bad, so changed it and put a new filter on. Fired her up made good pressure and ran for another 5000 miles till a ring went and the oil consumption and smoke from the breathers was unbearable, another 1000 or so. I'll admit I think i was very lucky, but don't give up hope till you have properly assessed
#74 conlad
conlad
  • 2,054 posts
Posted 11 March 2013 - 10:21 PM
Hi mate
Great story eh!!
I think the fact oil just poured from somewhere underneath just made me think it'll be easier to swap to save time and effort diagnosing this engine while in the car...
Like above, I can keep or flog my old one if needs be
