Those wheels are looking really smart. nice one!
84 Mini25 Resto 2.0
#421
Posted 28 October 2025 - 10:28 AM
#422
Posted 28 October 2025 - 05:35 PM
When confronted had the cheek to blame the 'rattle can' paint being soft. They aren't ****ing rattle can paint, they were baked in an oven and left in the warmth of the dining room for a few days. It's ok though it's not like I've gone to any effort or expense at all as you pretend to not understand english until payment is involved.
So, I've had to touch up with a brush the scratches (down to bare metal) which I know most people wouldn't care about (or see) but gone of the day of doing a job properly or with care. (It's always tyres, the last two times 2 different places couldn't fit directional tyres the right way round (also had tyre sensors so you couldn't just swap the wheels round) and short, not long tyre valves on wheels with hubcap, which makes getting at the valves impossible without removing the hubcaps each time)
And see how it drives and if they have been balanced properly, or I'll then have to find somewhere else to have them rebalanced properly. It's just as well they never fitted them to the car or I'd probably have ended up with it jacked up on the floor pans.
But so far I've spent £129 on 5 tyres, £300 on the stripping, blasting and painting and another £75 on the 'fitting', so just under a fiver over £500 for what is basically a standard boring set of steel wheels. It would have been cheaper and easier to just throw on a new set of alloys.
It also got a bit too late in the day for some proper overall car pics, as it was a bit of a struggle fitting the rears with it on axle stands in a single garage. Then rolling it outside (the only pair of spare wheels have, have less than optimal 14 year old tyres) to swap over the fronts.
20251030_042017.jpg 29.51K
2 downloads
20251030_043408.jpg 27.69K
2 downloads
VID_20251028_145346_exported_2195.jpg 30.13K
2 downloads
VID_20251028_145346_exported_7970.jpg 31.84K
2 downloads
VID_20251028_145421_exported_6726.jpg 28.5K
1 downloads
VID_20251028_145430_exported_1823.jpg 46.6K
2 downloads
Edited by 1984mini25, 30 October 2025 - 04:37 PM.
#423
Posted 28 October 2025 - 05:54 PM
The ones I'd found to use from a thermostat kit turns out won't work, as they are about half a nut too short so I'll have to reuse the ones already on the car. I did have some new ones spare and even some in an alloy manifold, but do you think I can find them? The studs I can understand being easily hidden, but an alloy manifold is a little larger and shinier to lose.
#424
Posted 30 October 2025 - 04:48 PM
But I think it's pretty obvious that the old manifold was leaking even with two gaskets. I've yet to check the old manifold, but I'm assuming the flanges are all going to be uneven with each other. I might try refacing it or chop the exhaust section off just for the inlet.
Oh, and it's looking like I'll have to take it elsewhere for the wheels to be rebalanced properly, these weights (for alloys not steels) are just waiting to fall off (wasn't the cheapest quote I got either)
IMG_20251029_164410_2.jpg 41.15K
1 downloads
IMG_20251029_164430_9.jpg 80.11K
1 downloads
IMG_20251029_164449_6.jpg 41.88K
2 downloads
IMG_20251029_170147_9.jpg 49.2K
2 downloads
IMG_20251030_131014_3.jpg 28.96K
3 downloads
Edited by 1984mini25, 30 October 2025 - 04:54 PM.
#425
Posted 31 October 2025 - 09:48 AM
#426
Posted 31 October 2025 - 10:52 AM
And with a lot of mini and smaller wheels there is clearance issues on the front with the brake calipers.
Knock on weights are quicker and simpler.
But as this is this garages second attempt and was happy enough to send them out of the door, I'm not going back, instead I'm leaving an honest Google review.
What annoys me is I have 23 years of tyre fitting experience (also Michelin trained from working at Costco) something that clearly the tyre fitter doesn't have. It's not like tyre fitting isn't day/week one of nvq level 1 motor vehicle college courses, anyone with a bit of intelligence and common sense can fit tyres correctly.
Edited by 1984mini25, 31 October 2025 - 01:38 PM.
#427
Posted 31 October 2025 - 11:29 AM
#428
Posted 31 October 2025 - 01:02 PM
Or 'balance it' stick the weights on and done out the door, rather than checking it, or worse adding more weight the second and third time to counterbalance the incorrectly placed first lot of weights.
The most the old tyres needed on the same rims was 50g, with the others all needing around half and less than that.
#429
Posted 01 November 2025 - 04:01 PM
#430
Posted 05 November 2025 - 08:44 PM
Still, the other vehicle is due it's mot at the end of the week, could do with a service (I'll do that myself as it's easy and I want the right oil being used) and a new set of tyres.
Which depending upon how the mot goes is a tad inconvenient, as now the weights on both fronts have fallen off and the one remaining one on the rear I've removed (it was rolling round on the rim) and am stuck with having to stick to below 50mph until they are rebalanced again.
I have managed to sand down and spot repair the deep scratched caused to the paint on the wheels. Luckly I had them sprayed in a standard wheel silver, so had a rattle can spare that was an exact match and some clear.
Edited by 1984mini25, 05 November 2025 - 08:45 PM.
#431
Posted 05 November 2025 - 08:51 PM
IMG_20251105_145852_1.jpg 31K
1 downloads
IMG_20251105_145921_8.jpg 24.77K
2 downloads
#432
Posted 26 November 2025 - 12:50 AM
I also got a reasonable quote for getting the mini wheels rebalanced for the following day. Removed the wheels from the mini again (not easy to do in a single garage) loaded them into the other car and dropped them off the following morning, only to find they couldn't do them until the afternoon or to rebook for the following week and that it was going to be more expensive than what I'd been previously quoted.
So I reluctantly left them before explaining exactly how I wanted them balanced, and not to scratch up the paint etc. Upon returning later that afternoon/early evening, I find a set of 5 wheels all balanced with the correct weights (not excessive either) and no further marks or scratches to the wheels and another £45 lighter.
I do have some ugly wheel weights to mask up and paint, but I can live with that until the spring.
What was also rather annoying was upon refitting the wheels back onto the mini, something within the ratchet part of my torque wrench decided to let go and jam up. Thankfully being a decent branded torque wrench (bought 20 years ago and not abused) I've since been able to buy a repair kit and fix it so it's fully functional again.
But with the wheels, tyres and balancing fiasco now over you'd think that would be it with the mini, not likely.
With the ignition side of things now sorted (with the exception of the ignition advance) the standard needle is far too lean, so swapped it back to a new one of what it was last tuned with. Unfortunately in doing so I lost the little spring on the end of the needle. I tried looking for were I think it flew off in the garage, but couldn't find it. Luckly a spare carb that's been used and robbed for parts still had one I could use.
It's so much better and driving back to how it used to, but upon returning home and later checking the levels I found no coolant in the radiator (or at least below the fins in the radiator) I don't remember it ever getting above normal on the gauge (which are known for lying) and I didn't drive it that far with the reduced amount of coolant. (Although I'm not too sure how long the coolant had been low for)
Checked the obvious places for leaks and nothing been leaking onto the garage floor when parked up. And then discovered the newly fitted heater valve by the steering column leaking at both hoses. 2 new jubilee clips, a top up of coolant/antifreeze (about half a pint) and running up for 20 minutes and all happy and leak free.
That was until the next day and finding a fresh drip of blue coolant off the bottom hose to the heater matrix. Quick peek inside with an inspection camera (lidl/Parkside and good enough for diy use) and find the inside swimming with coolant. Oh, joy, so for now I've removed the heater unit and done a heater deleat and bypassed the hoses into each other (also removing the heater valve) and cable tired the hoses up under the dashrail.
Not ideal as it's now bloody freezing and I've got parts of a dissaembled heater spread up at the house. As I've removed and looked over the matrix and it's got the tiniest leak were it's crimed over onto the plastic tank at one end. I did think about pressure testing it, but if it's leaking the only thing it's fit for is the bin anyway, so I've just bought the same £20 heater matrix (mini specialists are £40 dearer for the same one) off eBay. The old one I've worked out at probably being 15 years old anyway.
But, as the heater unit is now apart, all the foam is scrap as it's soaked it's now all apart, being sanded, primed and painted (was given an external tart up before being refitted in 2017) and fitted with a new matrix and sealing foam (the left over yoga mats from my sound insulation)
Edited by 1984mini25, 26 November 2025 - 12:55 AM.
#433
Posted 09 December 2025 - 02:59 PM
I had been driving it without a heater, but wasn't ideal. Also, without the heater plumed in the engine temperature was running between normal and hot, which again isn't ideal and isn't normal running for this time of year.
Ideally, what I'd prefer would have been to do a coolant/radiator flush and then fit the reconditioned heater unit. But that's not exactly ideal, so that's a job for spring in the new year.
IMG_20251209_132825_9.jpg 45.68K
1 downloads
IMG_20251209_132830_9.jpg 42.14K
1 downloads
IMG_20251209_132933_7.jpg 25.76K
1 downloads
IMG_20251209_132947_4.jpg 35.57K
1 downloads
Edited by 1984mini25, 09 December 2025 - 03:01 PM.
#434
Posted 17 December 2025 - 12:10 AM
Also refitting and having the extra flow through the heater has made zero difference to the engine running temp (once it does warm up) which is slightly annoying and will need further investigation. I do also have an electric fan in the inner wing, but that has zero effect when on the move.
One issue that has been getting worse though was selecting 2nd gear without (and sometimes with) crunching. It was getting to the point I was thinking on swapping the gearbox with a rebuilt one I have (under another engine) but I've no clue (can't remember) what diff is in that one and without pulling the engine and gearbox out I don't know what's currently fitted.
I'm pretty sure it wasn't the clutch as I've only recently (September) just replaced the clutch slave cylinder and bleed it all through.
Although I did have the idea of getting under it and removing the plate on the bottom of the gearstick housing. It was all removed from the car, cleaned up, painted, regressed and refitted with new mounts only 5 years ago, but I didn't like the look of the grease inside, so removed and cleaned out as much as I could with spirits and rags as I could (also removed the gearstick from inside the car to do the same) and regreased it with a packet of left over cv grease.
It's now so much easier to change gear with a lot less resistance and crunching into second (only really when really cold) so I can put off the gearbox swap for now, but will need to be at some point. As since fitting my new exhaust 3 years ago the driver's side diff cover has been leaking were the thread for the bottom bolt also shared with the exhaust mounting bracket is non-existent, and I've got some wire wrapped round the bolt/forced it to hold, so would leave me in a bit of a mess if removed.
#435
Posted 19 December 2025 - 03:27 PM
Either side of the cylinder head was 82°
The inlet and outlet heater pipes in the engine bay were around 64°
The inlet hose on the heater was 34°(heater valve on)
The outlet hose on the heater was 64°
The top hose to the radiator was about 60° and the bottom hose was 58° to 60°
So I have a heater matrix working in reverse (plumed in correctly) and a radiator that's is doing nothing or very little.
Thinking either thermostat, which is an 82° one and was working on the stove before refitting when the head was swapped. To drain and chemical flush the cooling system/radiator, or as it's got to be drained and refilled with fresh coolant anyway and just replacing the radiator with a brand new one.
Edited by 1984mini25, 19 December 2025 - 03:28 PM.
