Bet You Can't Tell Me What This Is!
suspension brakes
29 replies to this topic
#16 Pickwah
Pickwah
  • 190 posts
Posted 11 May 2013 - 04:45 PM
At slower speeds,
easy way to see if its engine related or suspension related, drive down a big hill and turn you engine off, (preferbly not on a bussy road) if the noise is gone then its engine related and vise-versa, honestly it sounds like a wheel bearing or similar,
The video was me driving down a rather steep hill not In gear. Didn't switch engine off due to the servo on the breaks (needed to stop at the bottom haha).
It definitely isn't the wheel bearings as there is no play in the wheel and they have been replaced twice in case they were faulty!
Really hope it isn't diff/gearbox related as its my everyday car >_<
#17 Pickwah
Pickwah
  • 190 posts
Posted 11 May 2013 - 04:47 PM
At slower speeds it does just sound like its something dragging/catching, but it is still quite loud!
#18 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 11 May 2013 - 04:56 PM
rather risky thing to do and i take no responsibility to damage, injury or death, but am still alive ;)
put the car on axle stands so it is secure, get some body to drive the car to about 10 mph while you look under the car and identify where the sound is coming from.
or take it to a garage, like you say it could be diff related.
#19 MrBounce
MrBounce
  • 2,563 posts
Posted 11 May 2013 - 05:17 PM
Just throwing it out there - could you have a cracked subframe?
#20 Pickwah
Pickwah
  • 190 posts
Posted 12 May 2013 - 09:32 AM
Im pretty sure I don't have a crack, but it is running on solid mounts? Will this make a difference?
#21 Pickwah
Pickwah
  • 190 posts
Posted 12 May 2013 - 09:33 AM
Ill give this a go! Ive done it before but this time ill jack up the suspension too so everything sits as it would on the road. As long as it is all on axel stands I cant see it being too dangerous
#22 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 12 May 2013 - 12:51 PM
Damaged speedo cable?
#23 firstforward
firstforward
  • 824 posts
Posted 12 May 2013 - 01:07 PM
Does this come and go as you turn the steering?
#24 ianclark1275
ianclark1275
  • 56 posts
  • Local Club: Minicross drivers association
Posted 12 May 2013 - 10:08 PM
sounds like diff to me.
IC
#25 its_courts28
its_courts28
  • 644 posts
Posted 13 May 2013 - 03:21 PM
Your mini has little car syndrome and wants to be a train instead...
#26 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 13 May 2013 - 04:25 PM
Cheap LCB rubbing on the drive shaft......
thats a possibility
#27 62S
62S
  • 1,242 posts
  • Local Club: You must be joking!
Posted 14 May 2013 - 05:42 AM
That sounds like a serious wheel bearing failure. Did you put the correct grease in when you changed them?
Edited by 62S, 14 May 2013 - 05:44 AM.
#28 Pickwah
Pickwah
  • 190 posts
Posted 21 May 2013 - 11:56 AM
thats a possibility
Never thought of this!
#29 Pickwah
Pickwah
  • 190 posts
Posted 21 May 2013 - 11:57 AM
Yeah  I put the right grease in.. Used the stuff that came with the kit
#30 Ethel
  • 25,418 posts
Posted 21 May 2013 - 12:47 PM
If it was the lcb catching, jacking it up shouldn't make a difference. You could use your brakes to create some resistance while it's in the air, even clamp off a hose at a time to drive just  one wheel. Make sure it's very secure, of course. Take the front wheels off, put something under the floor as a back up and use a length of hose as a "stethascope" rather than getting underneath yourself.
Also tagged with one or more of these keywords: suspension, brakes
