Cylinder Head And Block Skimming
engine
11 replies to this topic
#1 MiniElliott
MiniElliott
  • 378 posts
Posted 28 May 2013 - 09:43 PM
Hi,
Would anyone be able to tell me if it's capable of skimming a cylinder head and block on a standard mill with a standard face cutting bit ?
My friend works for a machining firm/ blacksmiths and reckons his boss would be able to skim the our blocks for free. However I have only ever heard of blocks and heads being skimmed with a grinding wheel.
Is this a viable option providing the mill is large enough ?
My main worry is that the slightly rough surface finish might cause head gasket problems.
Elliott
#2 mini13
mini13
  • 3,811 posts
Posted 28 May 2013 - 09:46 PM
Yes, lots of blocks get done like this
#3 jaydee
jaydee
  • 8,565 posts
Posted 28 May 2013 - 09:47 PM
You can do that, but have to leave a minimal piston to block clearance
#4 MiniElliott
MiniElliott
  • 378 posts
Posted 29 May 2013 - 11:49 AM
Thanks for the replies.
Does anyone know what the minimum piston to block height should be ?
#5 carbon
carbon
  • 2,590 posts
Posted 29 May 2013 - 04:51 PM
Minimum piston-cylinder head clearance depends on the exact spec of the motor. For most units about 10 thou below the face of the block is about right.
The slightly ridged finish from the fly-cutter should not be a problem, if done well it may actually help the gasket 'bite' and seal properly between the bores.
#6 ianclark1275
ianclark1275
  • 56 posts
  • Local Club: Minicross drivers association
Posted 29 May 2013 - 09:14 PM
having the pistons level with block in DV's opinion is a good thing
ive run them +5 thou proud of block before ;-)
#7 mini13
mini13
  • 3,811 posts
Posted 29 May 2013 - 09:19 PM
for 1330 and under I aim for flush, for 73 and 73.5 I am for -5 to -10 thou as the gasket can get close to the piston.
#8 MiniElliott
MiniElliott
  • 378 posts
Posted 30 May 2013 - 09:04 AM
Thanks, the engine is a 1310 using a standard crank.
#9 nz_seamless
nz_seamless
  • 68 posts
Posted 09 October 2013 - 07:17 AM
When you say -5 to -10 do you mean five to ten thou proud of the deck or five to ten lower than the deck face?
#10 mini13
mini13
  • 3,811 posts
Posted 09 October 2013 - 03:39 PM
lower than the face.
#11 Cooperman
  • 23,322 posts
Posted 09 October 2013 - 06:14 PM
I aim for zero to 0.005" block deck to piston crown.
#12 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 10 October 2013 - 04:42 PM
I usually go for .020" below following the advice of some very eminent practitioners.
