My 1979 Mini 1000 came back after having a new clutch and coil today, but I've found that none of the headlights, side lights, tail lights and dash lights are working. The headlights do flash from the column stalk though.
I suspected a dodgy switch so I checked it with a multimeter. The switch has power, but bypassing it with paperclips doesn't work.
Given that it's all of the lights that don't work apart from the flash switch, I'm stumped as to what it could be. Everything else electrical works fine and the fuses are fine.
Help?!
