Posted 28 June 2013 - 12:00 PM
Posted 28 June 2013 - 08:43 PM
With a 100 bhp engine you are into the realms of needing a closer ratio straight cut gearbox and a lower final drive ratio.
As it will be revving very high it will need a centre main bearing strap and a full dynamic balancing.
The place to start is by deciding what the car's actual use will be.If it is for real competition then go for 100+ bhp. If not, then keep it a a nice road engine with maybe 85 bhp, standard gearing, good low-end torque and good reliability.
To build a 100 bhp engine and transmission which will work well and be, in relative terms, reliable, is very expensive, maybe £2500+.
Mini Technical Sections →
Problems, Questions and Technical →
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
Ac Dodd TuningStarted by Kevybmini , 04 Jun 2025 ![]() |
Am I Missing Something?Started by Rubbershorts , 21 May 2025 ![]() |
About To Do A Horrible Job - Wish Me Luck And TipsStarted by floormanager , 01 May 2025 ![]() |
Which Idler Gear Bearing Is Correct?Started by JimmyStinkpickle , 28 Apr 2025 ![]() |
