Posted 08 July 2013 - 06:44 PM
Posted 08 July 2013 - 06:45 PM
Get some engine degreaser and give it all a good clean so that you can see where the oil is coming out1
Posted 08 July 2013 - 07:07 PM
clean up and look for it coming out, a lot of people will tell you things like they were made with leaks, drip tray on display floor, specially designed to show if you have oil in your car and to stop the subframe rusting... it depends how long it takes for it to leak out, mine used to have a slow leak but a full seal and gasket change fixed that
Posted 09 July 2013 - 04:53 AM
Mini Technical Sections →
Problems, Questions and Technical →
1966 Mini S - Clutch IssuesStarted by MBradbury73 , Yesterday, 07:03 PM ![]() |
Ac Dodd TuningStarted by Kevybmini , 04 Jun 2025 ![]() |
Am I Missing Something?Started by Rubbershorts , 21 May 2025 ![]() |
About To Do A Horrible Job - Wish Me Luck And TipsStarted by floormanager , 01 May 2025 ![]() |
Which Idler Gear Bearing Is Correct?Started by JimmyStinkpickle , 28 Apr 2025 ![]() |
