Riding On Bump Stops (Well Almost)
49 replies to this topic
#31 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 18 July 2013 - 06:38 PM
Spent some moire time fine tuning the height adjustments. It is a real pain!
Annoying that my front geometry will be (may be out), i will need to get that checked (though i only raised it 1cm)
Anyway the finished result. As said above the ride is nice and smooth now. So all in all pretty happy.
#32 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 18 July 2013 - 07:01 PM
that looks perfect, really good look. what gap have you got now on the bump stops?
#33 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 18 July 2013 - 07:05 PM
1 sweaty finger or around 13mm
#34 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 18 July 2013 - 07:09 PM
bit of a hijack but are you still on standard height shocks or lowered?
#35 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 18 July 2013 - 07:25 PM
Actually the lowered! (gaz lowered)
There seems to be enough travel in them at this ride height. I had intended visiting http://www.calverst....per_lengths.htm and making sure.
Though all input welcome.
#36 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 18 July 2013 - 07:31 PM
cool thanks.
I'm going to be fitting 10's to my sports pack over the next week or so.
#37 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 18 July 2013 - 07:32 PM
Thats not a dumb question at all.
I know theres the common misunderstanding that rolling radius are the same, i dont know exactly where it comes from, proably due to fact they're within a percentage of difference that makes the swap legal.
Anyhow thats incorrect, get wheels of different diameter and have a look youself. They're accutally bigger!!
If you make the maths it will turn out that:
A 12" wheel will make the mini sit about 0.7" higher
A 13" wheel will make the mini about 0.8" inch higher
(Tyre pressure will play his role though.)
PS:
Heres a compare-o rama for tyres, saves us to make all that maths for such a thing  :shifty:
http://www.mintylamb.../?page=tyre.htm
good link
#38 IainNeon91
IainNeon91
  • 1,287 posts
Posted 18 July 2013 - 08:33 PM
What step are your front Gaz shocks set to with that bump stop gap?
#39 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 18 July 2013 - 08:42 PM
Slightly softer than half way. How come...
#40 IainNeon91
IainNeon91
  • 1,287 posts
Posted 18 July 2013 - 08:55 PM
I just wondered  :D That's what i will set my Spax too
#41 Cerberus
Cerberus
  • 989 posts
Posted 18 July 2013 - 10:00 PM
PS:
If the radius of the wheel + tyre is the same though (as in exactly the same), then the centre of the wheel will be at the same point, regardless of wheel size.
Obviously the difference between the 10s and 13s etc is such that there isn't a tyre which can give an exact match for rolling radius, thus altering the centre point of the wheel and the ride height.
Not sure as there's anything legal to do with the rolling radius stuff, it just means the closer you can get, the more accurate your speedo will be without being recalibrated to the new wheel diameter.
#42 jaydee
jaydee
  • 8,565 posts
Posted 18 July 2013 - 10:54 PM
Think about it, if the radius is bigger the car sits higher...
#43 adam_93rio
adam_93rio
  • 3,271 posts
Posted 18 July 2013 - 11:10 PM
Just to clear it up, the ratio for adjusting front hi lows is about 1:3 so for every millimetre you change it at the hi low, the other end of the arm will be adjusted by 3mm
Only at the front the rear is 5:1.........
Correct, I did say front. Didn't think they were bothered about knowing th back ones. Although its the most frustrating thing lowering both sides by say 10mm then realising that one side donut settles higher. Takes so many tiny adjustments to get it sorted
#44 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 19 July 2013 - 04:34 AM
What he is saying I think is that a 12" rim and tyre may not have a bigger rolling radius than a 10" combination -
#45 jaydee
jaydee
  • 8,565 posts
Posted 19 July 2013 - 09:01 AM
So he stated wrong and should have seen the link i posted
