Starter Panel Wiring
electrical
6 replies to this topic
#1 IainNeon91
IainNeon91
  • 1,287 posts
Posted 05 August 2013 - 05:09 PM
Hi everyone.
I was wondering if anyone could give me a heads up on which wire i would have to connect to each point on the back of this 2 flick switch starter panel.
The green switch is for ignition stage 1 and the red switch stage 2, the button, obviously is the final stage.. Vroooooom!
Any help would be great!!
Iain.
#2 lrostoke
lrostoke
  • 6,923 posts
Posted 05 August 2013 - 05:31 PM
depending on the rating of the switches I'd go something like this
green switch
brown wire off loom in
then out you would need a wire going to the red switch and also going to the green light.
And also to any stage 1 items you want to come on such as radio.....you'd have to check wiring diagram for car.
red switch
feed in would be from green switch
feed out would be attached to the white wires in the loom and also to the red light. and also to the starter button
starter button feed in from red switch feed out goes to starter solenoid or relay, again check wiring.
the red and green lights would need either an earth or I guess you could make them oil and ignition wiring by replacing the earth with alternator small wire and oil pressure sender wire.
The above should then give you
green switch on, green light comes on plus radio live and red switch as power in
red switch on, green light comes on, starter button now live, coil live, plus anything else needing be live.
press button car starts and if green and red light wired to alternator and oil sender those lights go out ?? , if wired to earths they stay on
Edited by lrostoke, 05 August 2013 - 05:34 PM.
#3 IainNeon91
IainNeon91
  • 1,287 posts
Posted 05 August 2013 - 06:28 PM
Thank you!
But when you say 'in' on the switch, is that the bottom connection or the top?
#4 lrostoke
lrostoke
  • 6,923 posts
Posted 05 August 2013 - 06:40 PM
doesn't matter in this case... they are just on off switches, so power goes in one terminal and out the other when its on
#5 GraemeC
GraemeC
  • 7,441 posts
Posted 05 August 2013 - 06:41 PM
Shouldn't matter, the switch just joins the two together
#6 IainNeon91
IainNeon91
  • 1,287 posts
Posted 05 August 2013 - 08:15 PM
Ahh right, that makes sense! I'll just have to have a go i think haha
#7 spaulwill
spaulwill
  • 125 posts
  • Local Club: M4
Posted 05 August 2013 - 09:37 PM
the switch doesn't matter which side is in but the side you take the lights off need to come off the switched side or it will be permanently illuminated
