Time for another update. Its amazing what you get done when you don't have to go to work for a week. Well once again lots of piccys :)
Started getting the strength back into the drivers side...Inner and outer sills sorted. Still needs a few more welds in places with the mig, then grinding down and finishing. Want to get the car solid before dressing the repairs.
Then turned my attention to the front screen surround. It was in a bad way and was an absolute **** to remove but got there in the end.
Notice the resin that had been used to cover the rust. This was everywhere you see the grey primer
As this is a later car, unfortunately the roof and pillars are roll welded so not much chance of removing that with ease. Decided the best way to tackle this was to cut it back and spot weld through the three layers. Last thing i want is to cause distortion to my perfect roof panel trying to hack the old seam off.
Gutter cut off
Drilled spot welds on the door frame and cut the rest of the screen panel out on the pillar.
Screen panel removed
Theres something sexual about new Genuine MG Rover Panels ![]()
Well thats it for today. Will start bulkhead repairs tomorrow and hopefully get this new screen surround fitting.
Oh ive also polished my accelerator pedal :)
