im having problems with my idler gear it always seem to chatter when its warm ive tried to do it a few times but its always the same result. im wondering what gap starts to cause the noise if any body knows
Posted 26 August 2013 - 07:05 PM
Posted 26 August 2013 - 07:11 PM
Replace the idle gear bearings.......
Posted 26 August 2013 - 07:13 PM
i have with the torrington bearings
Posted 26 August 2013 - 07:19 PM
Ok your clearance for the idler is 3 to 8 thousands of a inch......
Tighter been quieter.........
Posted 26 August 2013 - 07:27 PM
ye i got the clearance from haynes and im pretty sure ive set it to 4 thou every time but when it gets warm it chatters till clutch is pressed so im wondering what clearance it actually takes for the idler to chatter and if my 4 thou is actually bigger because im doing it wrong
Posted 26 August 2013 - 07:31 PM
How are you measuring it ? Ideally you want the engine and box split. Then reassemble the gearbox and transfer housing with all gears and gaskets in place and the bolts torqued up. Then measure the clearance......
Posted 26 August 2013 - 07:45 PM
yep thats how im doing it
Posted 26 August 2013 - 09:20 PM
Are you dure its the idler gear and no excessive backlash in the main gearset, quite common.
AC
Posted 27 August 2013 - 05:49 PM
im not sure about backlash but ive took the full drop gears out of a engine i know was quite so im going to use them. i also wondered if when im putting rtv sealant on the gasket its affecting the preload?
Posted 27 August 2013 - 09:53 PM
Its a simple test, just hold the gearbox input gear and ratttle it backwards and forwards quickly, if you hear the noise thats your problem!
AC
Posted 28 August 2013 - 08:17 PM
cheers il try that. once ive set the idler gear to 3 though should i still be able to push it backwards and forwards slightly in the casing cheers
Mini Technical Sections →
Problems, Questions and Technical →
Ac Dodd TuningStarted by Kevybmini , 04 Jun 2025 ![]() |
Am I Missing Something?Started by Rubbershorts , 21 May 2025 ![]() |
About To Do A Horrible Job - Wish Me Luck And TipsStarted by floormanager , 01 May 2025 ![]() |
Which Idler Gear Bearing Is Correct?Started by JimmyStinkpickle , 28 Apr 2025 ![]() |
‘93 Spi Downpipe ReplacementStarted by ShabbyMini , 03 Apr 2025 ![]() |
