10 Inch Wheels On A Metro?
38 replies to this topic
#31 jmmini
jmmini
  • 711 posts
Posted 13 October 2013 - 10:01 PM
Individualise the front and rear gas units it helps a lot
#32 rally515
rally515
  • 3,848 posts
Posted 13 October 2013 - 10:04 PM
Another thing i,ve no idea how to do haha >_<
#33 bigrob
bigrob
  • 483 posts
Posted 13 October 2013 - 10:56 PM
Theres some conversion things you buy which i think fit on where they used to join together. About £20 a corner if im not mistaken?
I imagine sorting out anti-roll bars, lowering and individualisng the suspension, and some decent adjustable dampers would give an equal, if not better perfomance than coilovers?
#34 cradley-heathen
cradley-heathen
    Metro-Man
  • 2,481 posts
  • Local Club: spearmint rhino
Posted 14 October 2013 - 04:07 PM
i was originally considering converting to coilovers all round on mine, but then a friend sold me his spare hydrolastic pump so i thought i would try it first. i had never lowered one before, but had taken the rear end appart on a customers car a few years back so i had a good idea what was involved.
it is a doddle, and does make a huge difference, however it was fitting some decent front dampers that totally transformed my car, there is minimal body roll now, and the grip with the yokos has also proved to be excellent. i would say its now easier to drive than my mini was on fast roads/twisty country lanes, and its also more comfortable than the mini ever was too.
#35 bigrob
bigrob
  • 483 posts
Posted 16 October 2013 - 12:03 PM
Sounds like a worthwhile effort then. Is it literally just a case of cutting something down a bit?
#36 cradley-heathen
cradley-heathen
    Metro-Man
  • 2,481 posts
Posted 16 October 2013 - 05:30 PM
its a very similar prinicipal to how mini suspension works, there is a spring, a trumpet and then the radius arm/top arm depending on which end your working on.
you let the fluid out to relax the spring, put the spring and trumpet out, carefully cut the required amount off the end of the trumpet/rod, refit it all, and gas it back up again. simple as that really.
#37 bigrob
bigrob
  • 483 posts
Posted 14 February 2015 - 05:10 PM
Bringing an old thread back to life, i'm planning on lowering my new metro and putting on tens.
When it comes to cutting the rods, is it really obvious which bits need cutting? And i'm asuming all 4 are the same?
#38 Chance
Chance
  • 1,457 posts
Posted 14 February 2015 - 05:16 PM
http://www.metropowe...sp?id=12&mnu=12
That guide should make it more clear...it is pretty obvious when you get to it
#39 bigrob
bigrob
  • 483 posts
Posted 15 February 2015 - 12:12 AM
Brilliant cheers mate i've not seem that before
