I am wanting to do I metro brake conversion on my car but am not sure of everything that I need.
I know I need the calipers disks hoses and flanges off of a metro. Do I also need the metro hubs (the bit that turns) or can I just use the standard mini ones that are already on the car?
4 replies to this topic
Posted 26 October 2013 - 08:14 AM
Posted 26 October 2013 - 08:23 AM
There's several ways of doing this, you can either use the complete metro assembly including hubs, or I believe minispares sell bolts with metric shafts and imperial threads meaning you can use the mini hubs!
Posted 26 October 2013 - 08:40 AM
Cheers. I will use the mini hubs then as I have heard the metro ones cause camber problems
Posted 26 October 2013 - 09:06 AM
They do affect geometry, but I'm not sure whether this can be rectified with adjustable bottom arms.
Some people like the metro hubs as the ball joints don't need shimmed to set up
Posted 26 October 2013 - 09:14 AM
If the calipers fit on the standard hubs then that has got to be the way to go. The standard hubs were made for the car so why change them if you don't have to
Also tagged with one or more of these keywords: brakes, suspension
Mini Technical Sections →
Problems, Questions and Technical →
Adjusting Brake Bias For 7.5" Discs With Pdwa ValveStarted by Daniel Watkin , 16 Nov 2023 brakes |
Answered
Fam7821 Brake Limiter Valve - Mounted Upside Down?Started by tarnofsky , 29 Sep 2023 brakes |
Kent 286 Can & MotStarted by frosty90 , 07 Sep 2023 brakes |
Brake Master Cylinder ReplacementStarted by M I N I , 30 Aug 2023 brakes |
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
