Posted 03 December 2013 - 01:22 PM
Posted 03 December 2013 - 01:27 PM
Posted 03 December 2013 - 01:59 PM
Nice find... '206 head is in more common parlance a '295. I would suspect that an engine of that age unless already done will be very worn - so first off I'd tear it down and have a look at what's what and go from there. You'll also have (I think) a remote type gearchange to contend with rather than a rod change - a few different mountings aside no great issue - but if you're starting with a rod change mini then the tunnel will have to be modified to suit.. If not used in a mini before then it'll also probably have an unsuitable FD in it too....
1098's are a nice tractable engine - although it's fast approaching 30 years since I had one (in a clubby estate) so memory fades somewhat... they don't like revving too much though... personally I'd pinch the head and build up a high compression A+ 998 ...(for daily driving the head will need an UL conversion - that's a different debate!)
Edited by wile e coyote, 03 December 2013 - 02:00 PM.
Posted 03 December 2013 - 02:13 PM
Posted 03 December 2013 - 03:59 PM
Posted 03 December 2013 - 04:01 PM
The 1100 is good for usable torque but don't like to rev and usewd versions tend to burn oil.
I like a well set up 1100 personally.
Check the diff ratio too.
I have a remote change from an ADO 1100 or 1300 if you need one. They are different to the earlier mini ones.
Posted 03 December 2013 - 05:09 PM
If you currently run a rod change box and it's good, why not pop the 1098 onto that? Saves chopping the floor or bodging a mount. It will also leave your speedo reading correctly.
The 1098 engine is a long stroke so they don't rev like a 998, but they can be made to produce some useful torque. I believe you should have the AEA630 cam, which was also used in the 998 Cooper.
Posted 03 December 2013 - 05:51 PM
Mini Technical Sections →
Problems, Questions and Technical →
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
Ac Dodd TuningStarted by Kevybmini , 04 Jun 2025 ![]() |
Am I Missing Something?Started by Rubbershorts , 21 May 2025 ![]() |
About To Do A Horrible Job - Wish Me Luck And TipsStarted by floormanager , 01 May 2025 ![]() |
Which Idler Gear Bearing Is Correct?Started by JimmyStinkpickle , 28 Apr 2025 ![]() |
