Another Missfiring Mini
engine electrical
6 replies to this topic
#1 millett17
millett17
    Starting My Mini Up
  • 4 posts
Posted 08 December 2013 - 09:57 AM
hi this is the first time ive posted on here but im wondering if anyone can help?
i was driving down the M3 yesterday running really well so desided to put my foot down, but after a while my speedo needle started to drop even tho my foot hadnt moved, so i pulled of the m3 and turned my music down to hear that my car sounded like a bag of ****.
i thought it might me a hit lead that had broken so i left the engine running and took the ht leads off one at a time before replacing it and taking the next one off, when i removed first and fourth there was a change in the engine noice for the worst. however when i took second and third of the was no difference. i chcked to see there was a spark in these two cylinders and it all seemed to be ok.
please can some one help.
#2 Sheikh Pip
Sheikh Pip
  • 239 posts
  • Local Club: Sutton Coldfield Mini Club
Posted 08 December 2013 - 10:04 AM
I'd say the head gasket's gone between cylinders 2 and 3!
#3 millett17
millett17
    Starting My Mini Up
  • 4 posts
Posted 08 December 2013 - 11:35 AM
thats what i had feared mmmm getting home might be an issue then. thank you very much
#4 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 08 December 2013 - 02:54 PM
positive connection (from car loom) is loose, try tightening that, if its a points dizzy, change the points and condensor.
#5 Sheikh Pip
Sheikh Pip
  • 239 posts
Posted 09 December 2013 - 06:08 PM
Do a compression test, you can buy a test gauge for about £15!
#6 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 09 December 2013 - 06:35 PM
Certainly sounds like a head gasket problem if you have good spark on all four plugs. Maybe valve clearance out on the two non firing cylinders. Don't see how that suddenly happening on two adjacent cylinders though.
Edited by jime17, 09 December 2013 - 06:37 PM.
#7 millett17
millett17
    Starting My Mini Up
  • 4 posts
Posted 09 December 2013 - 06:37 PM
thank you so much for the help managed to get it recovered home and compression tested it today and the did the head gasket and alls good now
Also tagged with one or more of these keywords: engine, electrical
