Clutch Housing Wear From Flywheel
engine
Best Answer Jackrabbit18 , 24 June 2026 - 03:28 PM
Thank you all for the help. It's looking like I have a combination of issues that will require me to do some more investigating to see how far repairs will need to go.
Go to the full post
15 replies to this topic
#16 Earwax
Earwax
  • 603 posts
Posted 24 June 2026 - 09:15 PM
Although answered already I ask for others input into the amount of oil vapour getting past the seal.   ( or is there a possibility of a hairline crack in the actual transfer case - which allows oil through and perhaps adds a bit of unwanted movement)
It doesn't look like the flywheel is creeping up the crank taper - nor that the bolts in the ears of the backing plate are sticking through - but it does look like your oil pushing past the seal plus particle contaminants have made a rubbing paste if clearances were tight
    Bing (1)
