Megajolt Setup (Tps)
electrical
9 replies to this topic
#1 lawrence
lawrence
  • 1,341 posts
Posted 10 December 2013 - 05:49 PM
Hi there,
I recently won a megajolt setup from a well known auction site for a good price,
However I have a few problems, it wasn't the best advertised and seems to be the tps setup, which isn't the end of the world but I was hoping for a map setup version.
Now I've been searching for posts on the internet about this but I cannot seem to find an hif44 carb compatible throttle position sensor.
Can anyone lend a hand or is it possible to use the mj without the tps sensor?
Many thanks
Lawrence
#2 Domneon
Domneon
  • 720 posts
Posted 10 December 2013 - 05:51 PM
http://www.twinkam.c...d=24&aid=SC264
Voila!
#3 lawrence
lawrence
  • 1,341 posts
Posted 10 December 2013 - 05:55 PM
Cheers domneon, how did I not manage to find that i do not know. But it is £80 with vat and postage is a bit steep! Any other ones that may fit?
L
#4 Domneon
Domneon
  • 720 posts
Posted 10 December 2013 - 05:58 PM
Honestly mate I don't know, I just happened to know that they did them
#5 lawrence
lawrence
  • 1,341 posts
Posted 10 December 2013 - 06:00 PM
Cheers, I'm tempted to make a trip to a scrapjard and just look at loads till I find one that may fit, the wiring all seems universal 3 plugs which is nice
L
#6 l_jonez
l_jonez
  • 1,453 posts
Posted 10 December 2013 - 11:41 PM
Pretty sure you can buy a conversion board to swap to map.
#7 Ethel
  • 26,029 posts
Posted 11 December 2013 - 01:58 AM
Don't think the conversion is available anymore. If it's an earlier 'jolt, of the self assembly variety, you might source the components. Any tps should work as the software can map its output for you. You could even use an external MAP sensor but mapping it would be more of a challenge.
#8 mini13
mini13
  • 3,811 posts
Posted 11 December 2013 - 09:06 AM
TPS sensors often use the 3 way junior timer connector....
http://www.ebay.co.u...=item20d3f906b8
injectors and temp sensors are often the 2 way version.
TPS sensors are pretty cheap, I'd sugest getting somthing bosch, then you can reference the part no if you ever need to replace it. also bosch are pretty good for releasing datasheets.
http://www.ebay.co.u...=item1c39dc5deb
the bracket is probably not that hard to make, the tricky bit will be coupling the butterfly shaft to the TPS.
#9 Ethel
  • 26,029 posts
Posted 11 December 2013 - 01:03 PM
You really need the right crimp tool for JT's, so it might be better to salvage a length of loom along with a scrapyard TPS. I find Ebay really useful for browsing through the options rather than popping countless bonnets in search of something suitable.
#10 lawrence
lawrence
  • 1,341 posts
Posted 12 December 2013 - 08:16 AM
Cheers for your help guys, feel slightly less worried that I wasted quite a bit of money now! I think I'll go with your idea mini13 but like Ethel said get a chunk of loom with it too. I think i May profile down a steel rod to mimic the shaft and pop to the scrapyard to see what's compatible :) cheers guys
L
