Starting Issue - Fuel Supply Suspected, Gets Worse If I Don't Run The Car For A Day. Fuel Draining Away From Carb?
engine
15 replies to this topic
#1 Chrome_GT
Chrome_GT
  • 78 posts
Posted 26 January 2014 - 04:39 AM
Hi, My mini is getting some attention again after 4 years! Anyway here's my current problem #1.
The car doesn't seem to have fuel available when starting. It takes 20 seconds or more of good cranking before I get it to fire up. Once running it is fine. The other way to start it is turn it over using CRC Jumpstart into the carb. I think the two starting methods are achieving the same thing. They are spinning over the engine and priming the fuel lines. If i restart within hours then it starts fine. If I restart the next day then I have to go through this exercise of draining the battery or quirting jump-start into the carb. I suspect that my fuel is draining away from the carb if i don't run it regularly but am not sure.
I'm sure I'm not the first to have this problem but have failted to find anything similar in the forum search function.. Where should I start looking?
(Problem #2. Perhaps related, I find that in the first couple minutes of driving, i can't depress the accelerator too quickly or it goes all asthmatic and wants to cut out. If i press the accelerator gradually the revs keep up and the car doesn't want to cut out. This comes right once the car has done a few trips around the block. Not necesarily a cold/hot thing as I only tend to drive the car after it's been sitting idling after a good 5-10 mins)
Mini 1971.
Was 1000 but now 1310cc from a Morris 1300 with Factory Carb, standard air filter. I think I used my original 1000 mechanical fuel pump (I hope that isn't my problem).
thanks,
Ray
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 26 January 2014 - 08:13 AM
Is the choke operating correctly, and I'm sorry if this sounds rude, but do you know how to use it?
#3 grumpy dad
grumpy dad
  • 305 posts
Posted 26 January 2014 - 09:46 AM
Hi
its sounds like you are right
as the car has been standing for 4 years
there is bound to be muck in the tank
in the fuel pump there are 2 flap valves
sounds like there is muck it them
and thay are being held slightly open
thay are in the pump body
so you will have to take the pump of
put a in line fuel filter before the pump
2 quick fix for you
keep the tank full my guess is the top of the tank
and the carb are almost the same hight
so the pump will not have as far to lift
fit a SU electric pump in the boot
#4 Chrome_GT
Chrome_GT
  • 78 posts
Posted 26 January 2014 - 11:13 AM
Yeah chock seems to operate fine. Cable adjusted and operating the linkage as expected and idle goes up etc. I have issues starting the car regardless of whether the choke is in or not. Seems to make no difference there.
Flap valve sounds interesting, and fitting, so I'll definitely look into this further. This problem has been around pretty much the majority of the time since I took it off the road. I owe my cars some TLC.
#5 Chrome_GT
Chrome_GT
  • 78 posts
Posted 26 January 2014 - 11:16 AM
I'll try the fuel level suggestion too, will fill it up before the next startup and see if it starts earlier
#6 grumpy dad
grumpy dad
  • 305 posts
Posted 26 January 2014 - 12:35 PM
Hi
the first time you start up it will probley make no difference
but it should after that
#7 Shaley
Shaley
  • 154 posts
Posted 26 January 2014 - 09:10 PM
will watch this one too as having exactly the same issue..!
Was wondering if some sort of non return type valve could be introduced to stop the fuel dropping back?
#8 Dusky
Dusky
  • 5,322 posts
Posted 26 January 2014 - 10:47 PM
They sell additives to clean jets etc.
Maybe this could clean the fuel pump?
#9 Chrome_GT
Chrome_GT
  • 78 posts
Posted 28 January 2014 - 02:59 PM
Undid the hose from the pump to carb and tere was still fuel there after 12 hours since last running. So it must be a very slow leak back through the pumps inlet outlet valve(mentioned in te Haynes manual)
Haven't got the pump off yet. Quite an awkward positon!!!
The idea to put a check valve in line is quite a good one. Very easy to do, and cheap on eBay but it's hard to know what is good enough.
Does anyone know the pump displacement, flow per rev, for the pump? Maybe I should check the Haynes for this info.
I'll keep you posted
#10 Chrome_GT
Chrome_GT
  • 78 posts
Posted 28 January 2014 - 03:55 PM
How does the float bowl fit into this scenario. If the pump is allowing fuel to drain back through, does this drain fuel from the float bowl aswell? Or does the float bowl reserve a certain amount of fuel no matter what is happening in the supply line?
#11 cal844
cal844
  • 9,638 posts
  • Local Club: TFMOC
Posted 28 January 2014 - 08:39 PM
Change the fuel pump... The 1000cc pump wont have enough fuel psi
#12 grumpy dad
grumpy dad
  • 305 posts
Posted 28 January 2014 - 09:26 PM
Hi
if you put a check valve in
it must be before the pump
#13 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 28 January 2014 - 09:36 PM
The float bowl should retain the fuel it has (depending on which carb you have).
#14 Chrome_GT
Chrome_GT
  • 78 posts
Posted 29 January 2014 - 12:02 AM
Ok maybe i need to check the float bowl. The whole reason we were suspecting the pump is because i cannot start the car without spinning the engine over many times. It comes to life after 20 seconds or of cranking (unless I'm restarting within hours of the last time it ran). If the bowl has fuel then surely it should start straight away? I'll look inside the bowl before doing more with the pump.
It's the std SU for a Morris 1300 SU HS4. It's a single.
#15 Chrome_GT
Chrome_GT
  • 78 posts
Posted 29 January 2014 - 07:13 AM
The Float Bowl had plenty of fuel in it when i had a look tonight. I'll have a look in the morning. Since the Carburettor takes fuel from the bottom of the float bowl, and the inlet pipe to the bowl is at the top, I can't see how the fuel pump is the cause any more. But still keen to hear any thoughts.
