Posted 28 January 2014 - 11:31 PM
I know that electrical drains cause the idle speed to drop slightly, but putting my (halogen) headlights on causes a drop of about 350rpm and the alternator to faintly whine. It used to be that the longer I drove it, the less this gap became, but this hasn't been the case since winter started and I had to use the headlights more.
Also - and I'm not sure if this is related or not - restarting the engine when it's still hot, after half an hour say, will also cause a low idle speed until I've run it down the road a bit. Is this the electrical drain from recharging the battery after I've run the starter motor? Or a tuning/carb/ignition issue?
All the electrical equipment causes the engine to run slower, but the biggest culprit is the lights, followed by the heater. Ironically the rear screen heater has almost no effect whatsoever, though it is a bit useless.
Posted 28 January 2014 - 11:44 PM
This is normal behaviour, and its why modern cars with AC have a over-ride to up the engine idle when the air con is being used to avoid it stalling
To minimise this you will have to look at all the connections and check they are clean and well connected, any resistance create at these connections will ultimately draw more current from the battery. The slight squeal you are getting could be a worn out fan belt or just it being a bit loose, I would tighten it up and see if the squeal goes, if not a new fan belt isnt expensive
Posted 28 January 2014 - 11:45 PM
Normal as the electrical load increases the idle speed will drop and the whine is the alternator working if its not the belt not correctly tensioned, or its worn out
Edited by KernowCooper, 28 January 2014 - 11:46 PM.
Posted 29 January 2014 - 12:45 AM
Posted 29 January 2014 - 07:07 AM
Posted 29 January 2014 - 11:10 AM
Edited by jime17, 29 January 2014 - 11:15 AM.
Posted 29 January 2014 - 11:13 AM
Mini Technical Sections →
Problems, Questions and Technical →
Trying To Find The Right Wire Harness Online...Started by mattaebersold , 22 Jul 2025 ![]() |
Mini Rio 93 Boot Wiring IdentificationStarted by KanKanManKan , 11 Jul 2025 ![]() |
Rebuilt Engine Wont Crank With CompressionStarted by Kernreuben , 04 Jul 2025 ![]() |
1987 Mini Rover Fuel Gauge IssueStarted by kwfranky , 11 Jun 2025 ![]() |
![]() 1986 Mini Chelsea - Main Beam IssueStarted by Dominic1998 , 25 Apr 2025 ![]() |
