Charge Cooler Kit Vmaxscart
43 replies to this topic
#16 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 09 February 2014 - 09:31 PM
Yep, you can 100% water or a water meth mix norm around 50/50... But the pump needs to be compatible with meth
Edited by Gr4h4m, 09 February 2014 - 09:31 PM.
#17 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 10 February 2014 - 08:31 PM
What does the meth do?
#18 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 10 February 2014 - 10:51 PM
Meth burns slower and helps With knock, like running higher Ron fuel. So you get a double effect and maybe a bit more hp.
It's a bit scary... Have a google about it burning...
#19 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 11 February 2014 - 06:10 PM
It will allow you to run more ignition timing & more boost as the engine will be less prone to detonation. All being well, there's a decent power increase to be had.
Phil.
#20 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 11 February 2014 - 10:04 PM
Can you use any old methanol?
#21 Gremlin
Gremlin
  • 2,142 posts
Posted 11 February 2014 - 10:24 PM
What sort of nozzle size would be ideal if I was just using a windscreen washer pump?
#22 Gremlin
Gremlin
  • 2,142 posts
Posted 12 February 2014 - 10:17 PM
Anyone?
#23 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 12 February 2014 - 10:28 PM
Anyone?
Your question has already been answered, earlier on. 13th post.
Edited by HUBBA.HUBBA, 12 February 2014 - 10:29 PM.
#24 Gremlin
Gremlin
  • 2,142 posts
Posted 12 February 2014 - 10:56 PM
Yeah but thats very expensive, and it doesn't say how big the hole is, would 1mm diameter be ok?
#25 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 12 February 2014 - 11:20 PM
I use a .70 jet
#26 Gremlin
Gremlin
  • 2,142 posts
Posted 12 February 2014 - 11:27 PM
Thank you very much
#27 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 13 February 2014 - 12:12 AM
I would recommend buying a proper jet they are not cheap on eBay, the one I have has a built in filter
Edited by Gr4h4m, 13 February 2014 - 12:12 AM.
#28 Gremlin
Gremlin
  • 2,142 posts
Posted 13 February 2014 - 01:31 PM
From you saying .7mm was good for you, I thought about using a mig welding tip designed for .6mm wire
#29 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 13 February 2014 - 07:36 PM
Whats the welding tip made of?
#30 Gremlin
Gremlin
  • 2,142 posts
Posted 13 February 2014 - 08:53 PM
Looks to be brass but I aquired today an injector from my mates subaru, so I may use that
