Engine Wont Turn
101 replies to this topic
#61 fattasss
fattasss
  • 46 posts
Posted 20 February 2014 - 07:00 PM
hi, tried to rotate the crank via the 34mm bolt with long bar and not too much force but its still not bugging,
the diesel is still sitting in the bores as well, cars in 2nd gear and handbrake is off, I'm waiting for a Miracle!
#62 fattasss
fattasss
  • 46 posts
Posted 20 February 2014 - 07:01 PM
Anyone's got a complete engine that they want to sell?
#63 Carlos W
Carlos W
  • 10,115 posts
Posted 20 February 2014 - 07:02 PM
You either need to try and turn it over by rocking it in gear, or in neutral with a socket!
But as suggested it'd be easier to rock it in gear
#64 Dusky
Dusky
  • 5,322 posts
Posted 20 February 2014 - 07:06 PM
If you get really desperate you hire the 5 strong guys from you rlocal bar and make them push the car when in gear.. But a high risk on breaking piston rings..
#65 Carlos W
Carlos W
  • 10,115 posts
Posted 20 February 2014 - 07:08 PM
To be fair, it sounds like it needs to come apart anyway
#66 fattasss
fattasss
  • 46 posts
Posted 20 February 2014 - 07:19 PM
whats the chances that it will turn if pushed by 8 Fat guyS.
#67 fattasss
fattasss
  • 46 posts
Posted 20 February 2014 - 07:20 PM
Could it be a clutch or flywheel issue?
#68 Dusky
Dusky
  • 5,322 posts
Posted 20 February 2014 - 07:23 PM
Chances are 50% or it turns or it breaks....
Given the fact that it was in diesel so long I think it would move.. But piston rings are fragile :l
#69 clubman1976
clubman1976
  • 23 posts
Posted 20 February 2014 - 07:49 PM
Roofers Torch it is then!!
#70 Gremlin
Gremlin
  • 2,142 posts
Posted 20 February 2014 - 08:47 PM
Or get it as fast as you can in neutral then clutch, in gear, dump clutch
#71 clubman1976
clubman1976
  • 23 posts
Posted 20 February 2014 - 08:50 PM
Put your seatbelt on!!
#72 Icey
Icey
  • 1,586 posts
Posted 20 February 2014 - 11:20 PM
Lets be honest now, even if you did manage to turn it it's not going to be a healthy engine.
If it were me I'd be pulling the engine apart and getting it ready for a re-bore and a thorough inspection of everything else possible damaged by the water that's got in there.
#73 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 21 February 2014 - 03:38 AM
A bit of heat with a big flame like a roofers torch wouldn't hurt much either.
Cough* fire + diesel *cough*
Diesel is only really flammable under compression.  It certainly wont ignite when you try with a lighter! (misspent youth)  Okay, a roofers torch would produce enough heat to ignite it.  But not if you're careful ;D
I had figured that most people wouldn't bother trying it when the bore was full of fuel, but perhaps I was wrong.....
#74 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 21 February 2014 - 04:39 AM
The car needs to be in top gear and I would suggest that you try gently shocking the pistons to break them away from the corrosion. I'd also suggest that you'll get results by bumping the car backwards and forwards - If you have any mechanical sympathy then you'll feel the spring in the engine mounts and drive line and just go that far .
#75 fattasss
fattasss
  • 46 posts
Posted 23 February 2014 - 03:43 PM
Hi,
over the week end I towed the mini with another car and its still not managed to turn the engine, I belive thers  something locking the flywheel..
anyway I have sourced another 1275 complete running gear with low miles that I am getting fitted to my mini very soon.
ive had mini enthusiast come and look  at the running gear I have in the mini already and he confirmed its a 12h unit from a MG, also the head is a big valve head,
if someone is interested in the parts from my set up  than let me know as I need funds for my new engine...
