Please explain, with reference to the wiring diagram of any model variant of your choosing, how ONE fuse in the Mini can cause loss of BOTH main beams.
I don't expect an answer any time soon....
Posted 01 March 2014 - 02:10 PM
Posted 01 March 2014 - 03:51 PM
Because this crops up so often I have done the circuit diagram here http://www.theminifo...x/#entry3003421
showing the feeds in/out to the lights on the lighting circuit which shows the feed into the headlight switch is fed from the brown wire on the solenoid and not fused. Where as the later cars had a 24 fuse box and the lights were fused by seperate left and right circuits
Edited by KernowCooper, 01 March 2014 - 03:52 PM.
Posted 01 March 2014 - 04:57 PM
Good idea. I just hope that they read it!
Posted 02 March 2014 - 08:06 AM
You are so funny and you don't even know it.Good idea. I just hope that they read it!
Edited by HUBBA.HUBBA, 02 March 2014 - 08:15 AM.
Posted 02 March 2014 - 08:19 AM
Posted 02 March 2014 - 08:24 AM
Posted 11 March 2014 - 02:48 PM
Interesting topic. I have a similar problem with my mini at the moment. Dipped beams are not working but headlights are. When I switch to main beams (3rd position on the switch) I only get the side lights (same as 2nd position). Could be a faulty switch I suppose but replaced it only a year ago. I do plan on checking through the wiring, but all thoughts welcome.
Thanks,
Gavin
Posted 11 March 2014 - 05:04 PM
Check the feed out from the switch on the Blue/white wire, and follow it through, that way you can see if its the switch at fault Gavin
Posted 11 March 2014 - 08:05 PM
Thanks,
Gavin
Do they work when you flash them?
Posted 11 March 2014 - 08:39 PM
Flash would confirm the wiring outward is ok, then look at the switch
Posted 12 March 2014 - 09:37 AM
Many thanks guys. Flash seems to be working fine. Have ordered a new switch and will let you know the outcome!
Cheers,
Gavin
Posted 12 March 2014 - 07:40 PM
Edited by HUBBA.HUBBA, 12 March 2014 - 07:40 PM.
Posted 12 March 2014 - 10:16 PM
Mind your its a art stripping the switch for the first time, just take time and release the screws holding the switch to the front plate between thumb and fingers, carefully let it open being aware of the springs.transfer plate and nylon indents.
Posted 14 March 2014 - 03:48 PM
Just to keep you guys up to date, Its not the switch. I think it may actually be the stick on the steering column, so will have a look at that.
Cheers,
Gavin
Posted 14 March 2014 - 04:00 PM
Cheers,
Gavin
