carlukemini, on 03 Nov 2014 - 10:40 AM, said:My only experience of rear disc brakes has been on small cars in the past (wife's car), most recently a 1.4 polo. I hated them for one simple reason - they were doing such little work that they basically just corroded extremely quickly. The calipers were in good working order, no binding, no laziness, just didn't do enough work to keep the disc cleaned up. I put 3 or 4 sets of discs on the back of that car in the space of 6 years.
I have to suspect that the same situation could arise on a mini, if the brakes need to be setup to do very little. Do look very smart though, and it's an interesting engineering undertaking to do what you are doing. Be sure to feedback after a while how you find living with them. I think with all these things the proof comes in use. If they work well and turn out to be zero maintenance as you hope, then that will prove them to be a good idea as a conversion.
I have purchased many cars from new and never had rear brake disc corrosion until I replaced the original disks with aftermarket junk then I agree the disks on the edges tend to corrode somewhat. I have had a fair share of motorbikes with rear disc brakes and never suffered corrosion, as you will appreciate the rear brake on a bike does very little, its mainly on the front. There is only about 190Kg of total weight with the bikes I had but the disks perform really well at slow speed and high speed so I am not sure where the point mentioned here that brakes need heat to work fits in with how well motorcycle brakes work, because work they do.
If there was a choice of fitting disc or drums on the rear of a mini for the same price for me it would always be disc because of a maintenance point of view but then again I use my mini a lot, unfortunately rear discs are expensive and the mini drums work to a fashion so I keep with drums.
