Thanks a lot! That was a fast response!
Posted 19 March 2014 - 04:41 AM
Posted 19 March 2014 - 05:01 AM
Ah sorry, thought I had done something wrong lol
what makes you say that?I have a feeling that you aren't quite finished yet.
Read your posts - too many mysteries, battery going flat in a few minutes, then a quick charge and everything works again.
The worst sort of fault on ELV electricals are intermittant faults, you can expect them to reappear at some point.
It's not really a mystery, I had just kept to a few bare facts
The battery had been drained because I had left the headlights on, no headlights but the switch was still draining power hence the charge.
Before I had realised that the battery was flat I had taken the live feed on/off a few times and I believe this cleaned up the connection making it work
I may be overly optimistic but I'm really hoping you are wrong when you say it's coming back
Sorry, not having a dig, but the worse thing with low voltage faults is not finding them and having the problem disappear, it will certainly reappear again.
Hopefully they won't, but be prepared that they will.
Mini Technical Sections →
Problems, Questions and Technical →
Spi Auto Keep Dying After About 15 Mins Of Driving. Ideas?Started by Lilgreenmini , 28 Mar 2026 |
Question About WiringStarted by Chekako , 07 Feb 2026 |
Timing Scatter ? Two Marks On The Pulley At The Same Time…Started by corsicanwood , 21 Jan 2026 |
Auu1086 DizzyStarted by Sharks , 09 Sep 2025 |
Broken Headlight Stalk On InnocentiStarted by IceBlue , 25 Aug 2025 |
