Have you a workshop manual? follow the circuit into and out of the horn circuit and check for 12v at all stages into the stalk and out.
#16
Posted 16 March 2014 - 08:52 PM
#17
Posted 16 March 2014 - 08:55 PM
#18
Posted 16 March 2014 - 10:29 PM
Erm........live
power on battery connected
#19
Posted 16 March 2014 - 10:43 PM
Erm........live
Yes it was, but the hazards and indicators are fine now, just gotta brush up on my electrical skills to work out the multimeter and trace the horn and headlight issues
#20
Posted 16 March 2014 - 11:56 PM
This "should" be simple, and if I had been here earlier I would have strongly suggested finding a purple wire and checking that it has 12V on it. OK, I will still suggest that, as no-one else has, so far....
The purple circuit feeds the horn, headlight flasher, and possibly a few other items, depending on model, which need to be usable with the ignition off. The purple comes from the brown permanently live circuit via a fuse, so with that information you will know which fuse to double check.
Depending on model, the purple circuit may diverge in several directions from multiple lugs on the fuse terminal, or somehere else. But it should be live everywhere that you can find it, which includes the hazard flasher and headlight flasher switches, and the horn switch or relay (the horn circuit varied by model/year).
If you do find battery voltage on the purple, check that full voltage remains when you try the flasher etc, because a high resistance somewhere will still allow very close to full battery voltage to be detected by the multimeter, until a load is applied.
#21
Posted 17 March 2014 - 07:05 AM
thank you for such a comprehensive answer and I will check this out tonight. I am a complete amatuer to this so excuse my questions but to check voltage I place the multimeter on volts, put the black lead on an earth and find a spot on the purple wire to touch the red lead, I should then find voltage when I press the horn? Is this correct?This "should" be simple, and if I had been here earlier I would have strongly suggested finding a purple wire and checking that it has 12V on it. OK, I will still suggest that, as no-one else has, so far....
The headlight flasher has never worked ever since I had the car so I can't do this
The only places I can see the purple wire is directly out of the stalk, at the fuse box and then at the horn itself
#22
Posted 17 March 2014 - 09:33 PM
I know I've been trying to sort this out but I would've thought the battery would have died slowly and not just a sudden death!
#23
Posted 17 March 2014 - 10:47 PM
Had the battery on quick charge for one hour until it said full
Reattached the battery and the headlights came on! Checked the horn, working, checked the brake pressure warning, working!
The only wire I have touched tonight was the brown live feed to the fuse box so I'm guessing there was a problem there after all! So half my problems are over through fluke rather than knowledge!
All I'm missing now is brake lights.
#24
Posted 18 March 2014 - 12:59 PM
Are the connectors for the rear clusters underneath the boot liner or inside the car?
#25
Posted 18 March 2014 - 11:03 PM
Just the dash to go in and then off to the mot centre
Thanks for everyone's help
#26
Posted 18 March 2014 - 11:34 PM
I have a feeling that you aren't quite finished yet.
#27
Posted 18 March 2014 - 11:50 PM
what makes you say that?I have a feeling that you aren't quite finished yet.
#28
Posted 19 March 2014 - 12:03 AM
Read your posts - too many mysteries, battery going flat in a few minutes, then a quick charge and everything works again.
The worst sort of fault on ELV electricals are intermittant faults, you can expect them to reappear at some point.
#29
Posted 19 March 2014 - 01:44 AM
Ah sorry, thought I had done something wrong lol
It's not really a mystery, I had just kept to a few bare facts
The battery had been drained because I had left the headlights on, no headlights but the switch was still draining power hence the charge.
Before I had realised that the battery was flat I had taken the live feed on/off a few times and I believe this cleaned up the connection making it work
I may be overly optimistic but I'm really hoping you are wrong when you say it's coming back
#30
Posted 19 March 2014 - 02:51 AM
Sorry, not having a dig, but the worse thing with low voltage faults is not finding them and having the problem disappear, it will certainly reappear again.
Hopefully they won't, but be prepared that they will.
Mini Technical Sections →
Problems, Questions and Technical →
Spi Auto Keep Dying After About 15 Mins Of Driving. Ideas?Started by Lilgreenmini , 28 Mar 2026 |
Question About WiringStarted by Chekako , 07 Feb 2026 |
Timing Scatter ? Two Marks On The Pulley At The Same Time…Started by corsicanwood , 21 Jan 2026 |
Auu1086 DizzyStarted by Sharks , 09 Sep 2025 |
Broken Headlight Stalk On InnocentiStarted by IceBlue , 25 Aug 2025 |
