Hi. I am new to the site and I come with a big problem. I thought I had done my research and knew enough about mini's to be able to buy a Cooper and not get fleeced, but fear I may have failed. I know they change over the years so some 'give' has to be given. But I'm stumped with my new project and would seriously appreciate any help you can give.
It's meant to be a 997 Cooper. The VIN on the V5 is CA2S7 then a number over 675000. From what I've read the 997 didn't go above the 500k's. The engine number, again on the V5, is 9FD etc, but the 997 never had the positve crankcase ventilation(D), so is it a 998? That would fit in with the chassis number and engine number. But the V5 says 997.
There are numerous numbers cast onto the block. But most notably the fuel pump aperture is cast over. Not just a blanking plate, but no hole at all, no rivet or screw for anything, smooth. The form of the outlet is there but it's blanked/cast over as part of the casting. Now I know the Coopers had a pump at the rear of the car so is this normal? As for numbers, there is 12A467, under that WM(O,G or C, not sure), under that 23758F, then over near the "1000" aluminium plate that's rivetted to the case there is 301M sort of under the plate that juts out.
The gear box/sump has SM 22A363 on it and a number stamped 9F8538.
It has a breather cannister on the tappet cover but none on the rocker cover.
At a loss to explain it all. Can anyone please make sense of it, please?
I'm going to take the head off tomorrow, what should I look for with a 997 and 998, numbers, features?
Cheers all
