Gage
Posted 22 May 2014 - 12:38 PM
Posted 22 May 2014 - 01:20 PM
Update: The car is trying to start, she'll cough once or twice before the starter just whines. she wants to start!
Posted 22 May 2014 - 06:33 PM
have you done a basic engine tune? tappets, plugs, points and timing.
Posted 22 May 2014 - 06:40 PM
Posted 22 May 2014 - 06:47 PM
check condensor it may be faulty..(in Dizzy)
Posted 22 May 2014 - 06:53 PM
Posted 22 May 2014 - 06:57 PM
The condensor is on the coil
When did they move it there...?
Posted 22 May 2014 - 07:10 PM
Edited by Dan, 22 May 2014 - 07:53 PM.
Posted 22 May 2014 - 07:15 PM
Posted 24 May 2014 - 04:51 PM
Just tried cleaning up all the connectors on the solenoid, and it looks like there is a second earth running from the engine to the body, the one on the battery was replaced quite recently and also looks good.
tried jumping off of another car to ensure there was lots of nice power and still couldnt get her to go, RAC Man said that it sounded like the starter motor was engaging but kicking out again and to check the flywheel for any chipped teeth etc
other than that you reckon the distributor?
Posted 24 May 2014 - 04:56 PM
Posted 24 May 2014 - 05:21 PM
Car was previously bumped, before I changed the starter, so that means the dizzy checks out
The starter is spinning and connecting, the engine is coughing but not firing fully into life, checked the teeth and some look a little worn but they don't look bad enough to stop it starting, then again I wouldn't know I haven't had this before!
This starter motor sounds weirder than the last one (I know what I mean!) so I'm going to try again with the other one and see if any luck and take them all to a specialist/back to the shop!
Posted 25 May 2014 - 02:37 PM
I suggest not focusing on the starter motor at this time. You have said a couple of times that it is engaging, turning the engine over, and getting kicked out. Inertia starters are supposed to get kicked out when the engine starts to fire so that is normal. The fact that the engine is being turned by the starter is indication that it is doing what it is supposed to do.
The coughing and not starting when the engine turns over suggests you should probably focus on a general tune up as Kernow mentioned above. Go through the complete tune up process for the valves and ignition system replacing any worn or suspect parts as you go. If the engine still refuses to start after doing that, tip a thimble of gas down the carb throat and try to start the engine. If it fires to life and dies or has difficulty maintaining an idle, look for fuel related problems.
Posted 25 May 2014 - 02:47 PM
Do you have enough fuel in the tank? And Are you using the choke enough? ( 2 simple, maybe stupid questions, but if it was bumpstarting I guess these should be right..
Posted 25 May 2014 - 03:28 PM
Update: checked the points, they look okay, changed the condenser as I had one laying around and it made little/no improvement.
Went through the haynes manual tracing system and tried getting a spark of the HT Leads onto the block, didn't seem very strong, tried the one from the coil onto the block and it was much more powerful, this leads me to believe its a problem in the distributor?
Dusky: There's fuel in the tank, and I assume the rest is set up fine as the car runs okay once started, just can't get her to start!
Doug: Haven't done the engine tune, only have basic tools with me at uni/college!
Mini Technical Sections →
Problems, Questions and Technical →
Clutch Disengagement Issue - Cosworth Bda MiniStarted by cooperbloke , 01 Oct 2026 |
Turn Signal/indicatorsStarted by oldman1001 , 30 Sep 2026 |
12G202 On A 998Started by Mini30BVA , 28 Sep 2026 |
Engine Surging Then StallingStarted by Adge456 , 06 Sep 2026 |
Stuck Exhaust ValveStarted by JimmyStinkpickle , 28 Jul 2026 |
