Ignition Problems Now!
Best Answer foggy , 14 June 2014 - 10:34 AM
Thanks for all your help guys. I ordered a new module and that was it. Fitted tge module and shes purring away now :) Go to the full post
#16
Posted 11 June 2014 - 09:54 PM
#17
Posted 12 June 2014 - 07:07 AM
#18
Posted 12 June 2014 - 07:09 AM
#19
Posted 12 June 2014 - 09:09 AM
Link to test the Hall Trigger Unit is in my post no9 try that. While you there check the carbom brush inside the cap, look for tracking/cracking of the cap and rotor arm
#20
Posted 12 June 2014 - 09:18 AM
if you search under my name you will find the topic not so long ago. it was the module that was faulty in the distributor.
i got a replacement of them but already purchased a powerspark unit. complete unit dizzy and module and never looked back, much better built quality.
there is test when you put a sparkplug in the lead coming from the coil. put it against a good earth and then get a wire from the plus side or the negative side cant remember anymore( its in that topic kerniwcooper gave the idea for the test) you switch your ignition on. and then make a swift contact with the wire againt an earth point and if the plug sparks its the distributor.
freaker
#21
Posted 12 June 2014 - 10:39 AM
I have got a mate at work to sort me a bulb and soldered on wires to it so will be doing the Hall trigger test later.
The simonbbc dizzy has been good for a number of years, i will call them if it's the trigger and see how much it'l all cost me. hope it's not much!
#22
Posted 12 June 2014 - 11:52 AM
#23
Posted 12 June 2014 - 06:15 PM
#24
Posted 12 June 2014 - 08:07 PM
Bulb goes + and - of coil and you crank the car over, bulb flashes on/off trigger working, no flashing on/off trigger faulty
Edited by KernowCooper, 12 June 2014 - 08:07 PM.
#25
Posted 12 June 2014 - 08:29 PM
#26
Posted 12 June 2014 - 08:30 PM
#27
Posted 12 June 2014 - 09:10 PM
I'd say it's the module myself, did you take a look inside it?
#28
Posted 12 June 2014 - 09:18 PM
I did and it looked normal to be honest but what can you tell whats going on inside that little black box. When I phoned simonbbc who I got the powerspark unit from they did say they thought it to be the module and that the trigger wheel rarely goes.however the module is 25 quid and the trigger about 3 quid so might just go for both.
#29
Posted 14 June 2014 - 10:34 AM Best Answer
#30
Posted 14 June 2014 - 11:09 AM
Its nice to report back your findings so others can see the problem and the test of the module, thanks for that glad your sorted.
