Rear Wheels Rub On The Arch With My Coilovers
#16
Posted 20 July 2014 - 08:51 PM
#17
Posted 20 July 2014 - 09:13 PM
#18
Posted 20 July 2014 - 09:20 PM
Of course they will. They sit inside the envelope of the rear sub-frame. The rear wheel clearance issue is usually the clearance between the radius arm and the tyre.
Whatever you do, there may well still be a problem with the tyre hitting the wheel arch on 'bump' and the only solution might be a body modification to re-shape the basic wheel arch. This would be expensive, but modifications often do involve spending a lot of cash. However, rubber cone springs may well eliminate the problem.
Very wide wheels on a road car do tend to throw up problems.
#19
Posted 21 July 2014 - 04:40 AM
Ensure your bump stops are correctly fitted, this should eliminate unneccesary clashing of the suspension components.
For set up, get the car corner weighted, this envolves putting the car on a set of scales. as you wind the coilover/hi-low up and down it applys more pressure over the ground. Even weight will allow the more even, predictable drive and better handing characteristics.
He is running completely non standard components?
Winding the coilover up or down won't make an ounce of difference to individual ground pressure (within reason) - only way to change that is to change the C of G of the car.
#20
Posted 21 July 2014 - 05:45 PM
Umm... It does work that way...
http://robrobinette....rner_weight.htm
Easier than me typing it out... read that
or watch that
Edited by mini93, 21 July 2014 - 05:45 PM.
#21
Posted 21 July 2014 - 06:19 PM
wouldn't doing this make it worse seen as I will have to lower the rear?Ensure your bump stops are correctly fitted, this should eliminate unneccesary clashing of the suspension components.
or watch that
#22
Posted 21 July 2014 - 06:40 PM
The root cause of the problem is the coil springs which are not as good as the original rubber cone springs.
Answer is to re-fit the springs which were designed for the car, set the ride height to standard and then, if the wheels still rub, fit wheels which are nearer to the originals.
Then the problem will be gone forever.
#23
Posted 21 July 2014 - 06:50 PM
or watch that
No, its not really relevent in your case, any downward adjustment of the platford to even up the balance would just be detrimental to arch height, even if it is a small amount
Also tagged with one or more of these keywords: suspension
Mini Technical Sections →
Problems, Questions and Technical →
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
