My 1989 Flame Red was always a perfect runner, until I needed fresh front tyres in the winter.
After the fronts were fitted, the car steered to the right slightly but I had to leave for uni after the holiday.
3 months later, I got it booked in to fix the tracking which was apparently in by over 10mm, causing wear on the outside of each tyre.
The tracking was "fixed" and new tyres fitted but now it steers to the left A LOT. My mechanic said "it's not the worst I've driven but I can't see anything wrong with it".
Under breaking, the car straightens out - meaning I end up steering to the right because of correcting for the pulling.
The break pads are slightly worn, with the right side more so than the left but they don't seem too bad.
I'm using 31 PSI in each tyre, but they slowly deflate and get to around 28 by the end of a week... not sure which problem is causing which.
In addition, a grinding sound happens when I'm in full left lock whilst reversing. All stock suspension, with the track rod ends changed last year. Running on 12" rims with standard discs on the front and drums on the back. Any ideas? I just want it to be safe to drive! ![]()
Edited by gwilty755, 04 August 2014 - 02:33 PM.
