Renault Megane Scenic 1.9Dci Engine Swap
520 replies to this topic
#151 adam6900
adam6900
  • 12 posts
Posted 28 September 2014 - 04:49 PM
Honest mate its scrap, the noise sounds like its blowing out the back of the block from the head gasket, the smoke there is unburnt diesel smoke, they pop the gaskets out quite often when they run away (and it probably has due to the fact your original turbo was shot), could waste time pulling the head off, changing gaskets and valves, put it all back together again only for it to spin a crank or main bearing a month or so later,
If you really want it fixed, need to pull the engine out strip it, make sure none of the conrods are bent and the bores are ok, then new shells in the bottom end, new headgasket kit, new good used turbo (don't use a home rebuilt one it wont last) and put it all back together,
Sounds like the seller was less than honest tbf
(ps I break these and fix them for a living seen it all before)
#152 adam6900
adam6900
  • 12 posts
Posted 28 September 2014 - 04:51 PM
Just watched ya video, totally wasting your time that engine is missing compression on one cylinder, you can hear it clearly when it starts on the starter motor!!, its fit for the bin nothing else, chances are the turbo has stuck its oil in the intake and its run at 10,000 rpm until it ran out of oil.... needs a engine simple as that.
Damn!
Wish i had heard that 2 weeks ago.
Bugger
Easy way to tell low compression, crank it over with the leccy plugs disconnected off the injectors and you will hear it clearly as a little Speed up bit on the starter, the difference between that and a healthy engine is clear if you listen to both
#153 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 September 2014 - 05:00 PM
So hoe much is an engine Adam?
#154 adam6900
adam6900
  • 12 posts
Posted 28 September 2014 - 05:03 PM
Bare F9Q 716 £550 complete Drop in ready to go £800 Just not worth it on a old car to be honest (and my prices for good 716's are very low compared to most)
#155 adam6900
adam6900
  • 12 posts
And I am sold out at the min, but new ones every week or so
#156 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 September 2014 - 05:06 PM
I could throttle that lying bastard i bought it off.
Thanks for the advice adam, ill just scrap it
#157 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 28 September 2014 - 05:18 PM
Your bad luck never ends, can't believe this mate. Terrible news. Could you make a few quid by breaking it and selling stuff on? But appreciate you may just want to take it to a large field with a box of matches.
#158 adam6900
adam6900
  • 12 posts
Posted 28 September 2014 - 05:22 PM
Yeh break it, pull off Diesel pump, injectors, window mechs x4 speedo head, Ecu set with key bsi and engine ecu, gear cables, rear lights, rear boot struts, all 4 wheels, spare, jack, that lot will give you £400 back and scrap the rest, cats worth £30 on that age to (happy to buy the cat if you want rid)
#159 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 September 2014 - 05:26 PM
In theory i could, The wheels are nice and have 2 brand new tyres, The leather interior is really nice with no damage at all, It looks new! There are loads of good bits on it but i just don't know if there would be a market for it here on the island and i don't fancy trying to arrange shipping of an interior etc.
I just feel like i have been kicked hard in the nuts. The bloke i got it off must have known, yet he lied through his teeth to my face saying that he didn't have time to fix it and that he needed it out of the way hence the low price.
I just really need to get the money back on it because it's borrowed.
There is a breakers yard nearby that is family run. The blokes son deals with the parts side of things and has bought cars from me in the past. He is very good. I'm going to give him a call in the morning and see what he can offer me.
Ben
#160 adam6900
adam6900
  • 12 posts
 Diesel pump (£45) injectors(£18 each), window mechs x4 (£35 each) speedo head (30), Ecu set with key bsi and engine ecu( £110), gear cables(£30), rear lights (15 ea), rear boot struts£10 pair), all 4 wheels(50-£150 depending on tyres), spare (15), jack(15),
#161 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 September 2014 - 05:27 PM
Thanks mate, that's food for thought.
is the leather interior worth anything?
#162 adam6900
adam6900
  • 12 posts
Scrap yard will offer scrap money lol £90 ish, just take them bits off and send them with parcel2go rest is scrap and no seats not worth unbolting
Edited by adam6900, 28 September 2014 - 05:28 PM.
#163 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 September 2014 - 05:30 PM
Is the stuff likely to sell though or will i be constantly re listing it all for the rest of my life?
#164 Carlos W
Carlos W
  • 10,115 posts
Posted 28 September 2014 - 10:59 PM
You said that connecting and disconnecting the injector you replaced doesn't bring a fault light on the dash, but all the other ones do?
Can you trace those wires back and check for faults?
#165 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 28 September 2014 - 11:06 PM
I have traced back as far as i can but no joy.
Adam seems to know exactly what has happened to it and that is that it has run away before i bought it and they must have just topped it back up with oil and sold it to me.
He says it's scrap so not much point mucking about with it now. I think it's not firing on that cylinder because there is no compression for what ever reason. Apparently you can hear it when you turn it over on the starter.
I'm gutted
