After 24 Years, Another Capri
95 replies to this topic
#91 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 19 August 2015 - 08:25 PM
To be honest it's no where near as loud as my white one hahaha. I'll take you for a spin in the White one when you come down :)
sounds good!
#92 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 14 October 2015 - 10:50 AM
Attached File  20151011_100241.jpg   52.2K   9 downloads I keep forgetting to update this thread, its still coming on slow but sure. I am getting to the point of beginning to spray some of bits that will be hard to get to in the final spray. I still need to weld the one rear arch but decided to concentrate on a few jobs whilst the weather is still warm enough to paint.
#93 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 25 October 2015 - 02:41 PM
Fitted the door back on and swapped out the dodgy steering rack this morning. Only seven bolts on the rack and seemingly easy access to almost all of them suggested an easy job but it still took two hours. I think I could do another in half the time. Now need to set the tracking and get the steering wheel lined up and it's all done. Apart from fitting the rear seatbelts, that's all the mechanical jobs done.
#94 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 23 December 2015 - 05:23 PM
Still plugging away, onto the very last bit of welding now on the drivers side rear arch. Cut the outer section off today expecting a pile of rust that used to be the inner panel but it's solid apart from needing two patches. It will still be a few hours work but much better than expected. Also did some work on other bits that have been welded. So was skimming and painting and cringing while it all went off. Damn cold working outside though.
#95 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 18 January 2016 - 03:34 AM
Keep up the flow of pics Clive, love a Capri, lusted but never took the plunge.
#96 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 18 January 2016 - 07:20 AM
Will get some as soon as I can. We are in the middle of some building work at the moment so it's having to have a couple of months off and the builders have put a massive pile of bricks in front of the garage.
