Engine Really Smokey
71 replies to this topic
#1 BronkoMini
BronkoMini
  • 1,484 posts
  • Local Club: Mini Fixers
Posted 22 September 2014 - 06:30 PM
Hi all,
Engine
Std 998 crank, balanced with VP2 bearings. High capacity oil pump. Centre main strap. Bushed rods and +0.040" Hypatec pistons. MD274 cam. Standard 12G295 head with 28cc chambers, stainless valves, unleaded seats and double valve springs. Duplex. Std gearbox rebuilt with new bearings, centre oil pickup and 2.95 CWP on a 4 pin Diff. Heavy duty verto clutch on lightweight steel flywheel.
So the engine has only done a few thousand miles since being rebuilt.
Since putting the engine in it always had a slight smoke from the tappet cover breather.
Took the car to the rolling road and it had a slight smoke from the exhaust on the over run and the rolling road said it was probably the valves? but nothing to worry about, he checked the compression and it was good.
Since the rolling road I have only done a few hundred miles when on Friday, I was on a fairly long run on the motorway and there was a lot of stop start traffic, and the engine started to over heat so I turned on the heater and the temperature stayed at the halfway point.
Got to the half way point and stopped for five minuets then on the way back got stuck in town traffic all was well, then I got to a round about and the car just bogged down and there was a small tap rattle, but the engine still accelerated but slowly but the engine started to over heat.
Pulled over at the next safe point, turned of to let cool, car started again but wouldn't idle, and there was a fair bit of smoke from the tappet breather and coming out the rocker cover cap, the tap was faint, but as soon as I started to move it got louder.
I have looked on the forum and it looks like the smoke is caused by the piston rings, but I cant see how as its a (rebuilt engine)?
Here's a video
Thanks for reading, hope you can assist as I need the car for uni next week and I would like to get to castle combe.
Many thanks
#2 BronkoMini
BronkoMini
  • 1,484 posts
Posted 22 September 2014 - 06:31 PM
Oh also for the video I turned up the idle so it didn't die.
#3 carbon
carbon
  • 2,590 posts
Posted 22 September 2014 - 06:38 PM
Not sounding good.
I would suggest doing a compression check, and see what that tells you.
#4 Craig89
Craig89
  • 600 posts
Posted 22 September 2014 - 06:43 PM
Does look like piston ring failure the way the smoke is bellowing out of the oil cap.
Rich running when first running the engine in may have caused the bores to glaze over and the rings not bed in properly.
May be worth doing a compression test
#5 patricksouth
patricksouth
  • 298 posts
Sounds terminal to me possible big end,but someone will be along soon to point you in the right direction,i had the big end go on the way to imm and was gutted to have to turn around and go home.....
#6 sledgehammer
sledgehammer
  • 3,108 posts
Posted 22 September 2014 - 06:55 PM
Could be a leak on HG cyl to push rod hole - but unlikely - unless head stud weak
my money is on ring / piston damage - sadly
hope I'm wrong & it's something simple
compression test & look at plugs will reveal more
Edited by sledgehammer, 22 September 2014 - 06:56 PM.
#7 jpw1275
jpw1275
  • 2,803 posts
Posted 22 September 2014 - 06:56 PM
Looks like your manifold is leaking aswell
#8 BronkoMini
BronkoMini
  • 1,484 posts
Posted 22 September 2014 - 07:01 PM
Thanks for the replies, looks like I need to buy a compression tester, any recommendations?
#9 BronkoMini
BronkoMini
  • 1,484 posts
Posted 22 September 2014 - 07:03 PM
Video is not good quality but its properly the smoke from the tappet breather you can see.
#10 jpw1275
jpw1275
  • 2,803 posts
Posted 22 September 2014 - 07:04 PM
Does sound like you have a cracked or leaking manifold which could explain the sound but not the smoke pumping out of the rocker box
Cheers james
#11 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 22 September 2014 - 07:05 PM
Limp the car to your nearest garage (trailer/ tow pole if neccessary)
#12 jpw1275
jpw1275
  • 2,803 posts
Mine sounded similar and I found a crack underneath the manifold
Edited by jpw1275, 22 September 2014 - 07:06 PM.
#13 BronkoMini
BronkoMini
  • 1,484 posts
Posted 22 September 2014 - 07:08 PM
Okay ill have a look for any tomorrow.
I hate taking my car to garages, but if that's what's needed then I shall do that. I will have a ring round tomorrow.
#14 cal844
cal844
  • 9,645 posts
  • Local Club: TFMOC
Posted 22 September 2014 - 07:10 PM
All you need is a compression and leakdown test, wouldnt be expensive to diagnose
#15 BronkoMini
BronkoMini
  • 1,484 posts
Posted 22 September 2014 - 07:14 PM
Ah ok
