Engine Really Smokey
71 replies to this topic
#16 Gadgets
Gadgets
  • 471 posts
Posted 22 September 2014 - 07:45 PM
Tractor sounding, something isnt right, not missfueled with Derv have you by mistake?
#17 BronkoMini
BronkoMini
  • 1,484 posts
  • Local Club: Mini Fixers
Posted 22 September 2014 - 07:46 PM
Not miss fuelled, it was fine the whole way there but suddenly it just went funny.
#18 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 22 September 2014 - 09:16 PM
Id say its *******.......
Looks like excessive crank case pressure... Plus its misfiring too. If it was rebuilt, something wasn't done right. I'd take it out and start again.....
#19 BronkoMini
BronkoMini
  • 1,484 posts
Posted 22 September 2014 - 10:11 PM
The thing is I bought it off someone with a good reputation on turbo minis, so I'd have though it would have been done right. Really annoying as it cost a fair big and I thought it would be fine until I rebuilt my other engine slowly, but I guess not. :(
#20 jpw1275
jpw1275
  • 2,803 posts
Posted 23 September 2014 - 06:12 AM
Maybe you could contact them...?
Cheers james
#21 BronkoMini
BronkoMini
  • 1,484 posts
Posted 23 September 2014 - 09:06 AM
Cheers james
I'm not sure what to ask them and thanks for the many replys.
#22 ROD222
ROD222
    Just On Tickover
  • 7 posts
Posted 23 September 2014 - 09:21 AM
hi that is one sick engine ,one cylinder down ,could even be broken piston ,did you run it in (new engine?) tight boars? regd rod
#23 BronkoMini
BronkoMini
  • 1,484 posts
Posted 23 September 2014 - 10:37 AM
I bought it of someone that had it set up as a turbo engine, and he did a couple of thousand miles since it was rebuilt.
#24 silve1999
silve1999
  • 1,146 posts
  • Local Club: MiniFreakz, Brighton Mini Club
Posted 23 September 2014 - 10:52 AM
how long have you been running it (miles)
#25 BronkoMini
BronkoMini
  • 1,484 posts
Posted 23 September 2014 - 11:55 AM
Just over 500 miles
#26 BronkoMini
BronkoMini
  • 1,484 posts
Posted 23 September 2014 - 11:57 AM
And I haven't been revving it loads(fuel economy), rev limiter is set to 5700rpm and I have not hit it.
#27 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 23 September 2014 - 12:04 PM
How many breathers do you have on the engine? looks like a fair bit of crank pressure!
#28 BronkoMini
BronkoMini
  • 1,484 posts
Posted 23 September 2014 - 12:43 PM
Just the tappet breather and the rocker cover cap, I was in the process of looking into getting a catch tank and plumbing it into the rocker cover which came with the engine. A that's what they recommended at the rolling road, but I would not have though it was have caused the piston rings to give up.
#29 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 23 September 2014 - 02:04 PM
Hi,
As others have mentioned, I would agree with damaged rings and/or piston in one cylinder. The way the crankcase smoke is "chuffing" out of the filler cap hole and the fact the engine sounds like it's only running on 3 cylinders does point to one damaged set of rings/piston.
Again, as already stated, a compression check would be quick and easy and will help find the cylinder/piston at fault. If a check reveals one cylinder with a lower reading, its time to remove the head and see what the damage is.
Cheers, Steve.
#30 BronkoMini
BronkoMini
  • 1,484 posts
Posted 23 September 2014 - 02:21 PM
Thanks for the reply, I am going to take it to a garage tomorrow to compression test it as see what's what.
