Dose anyone know / can recommend a way of working out the RPM when setting the ignition timing on an engine? I don't have a rev counter.....
I was wondering if its worth getting a timing light with that feature built in?
Posted 24 October 2014 - 05:37 PM
Posted 24 October 2014 - 06:26 PM
No real easy way to tell what the rpm is without some sort of tacho, some experienced folk can tell and likewise with the timing. As a beginner myself I would recommend getting one I did and it made the job relatively simple. I bought the Accuspark one with the tacho built it works well setting the timing but the tacho is awful. In the end I used a calibrated digital one from work used for checking the speed of compressors. You can buy similar items on EBay for less than a tenner they come supplied with a roll of reflective tape, you put/stick a small piece on the crankshaft pulley aim the tacho at the tape and press the button and away you go the digital readout tells you the rpm.
Mini Technical Sections →
Problems, Questions and Technical →
1966 Mini S - Clutch IssuesStarted by MBradbury73 , Yesterday, 07:03 PM ![]() |
Ac Dodd TuningStarted by Kevybmini , 04 Jun 2025 ![]() |
Am I Missing Something?Started by Rubbershorts , 21 May 2025 ![]() |
About To Do A Horrible Job - Wish Me Luck And TipsStarted by floormanager , 01 May 2025 ![]() |
Which Idler Gear Bearing Is Correct?Started by JimmyStinkpickle , 28 Apr 2025 ![]() |
