Looking excellent!
I had the same issue with my rear seam. I just made up some new sections and welded them in. It came out fine.
You will easily be able to do the same with yours.
Keep up the great work
Ben
Thanks Ben!
I made a start, then decided I wasn't happy and had another go, not quite finished but much happier with the result....
First job was test fit of new panels....
Then whipped them off again and fitted the companion bin, although for some reason I don't seem to have any photo's of that so I'll post one another time.
On my first attempt I trimmed the rear panel a little so I had nice straight lines to work with, welded in some new metal and bent to shape using some slits to aid with getting the bend in the panel.
The result didn't look too bad but on close inspection there were a couple of little issues, first the shape wasn't a 100% match for the quarter panel and second the welds were very close to the bend, this second issue had two side effects, one was that the bend didn't have a sharp shape to it and the other being it was hard to adjust to get the shape to match the quarter panel.
So I decided to cut out further up into the rear panel, use a larger piece of steel, and cut more slits and this worked a treat.
After the first insert I went even further in with the cut out in the rear panel which made the job far easier.
The very top part looked like it would be trickier than it turned out to be as I would have to first shape the new piece to match the shape of the waist around the rear of the car, I was however able to make this up fairly easily and it worked at the first attempt.
It's fair to say I'm pretty pleased with this result but I do still have to grind the welds back and clean it all up (only done the face that meets the quarter panel for now to get it to fit) but it looks like this is going to be good, I also test fitted the quarter panel after each new section as I worked my way up the seam so it also now fits perfectly too.
Took me a few hours over a couple of days to get to this point but at least I am now happy with the result, didn't see the point in settling for something that I wasn't entirely happy with.
Edited by alchall, 29 August 2017 - 08:40 AM.
