I don't think all A+ 998 engines had press-fit rods, change from fully floating to press-fit was late 80's?
Others may be able to confirm.
Posted 20 December 2014 - 11:36 AM
Posted 20 December 2014 - 11:43 AM
probably right as they did like to overlap specs for a while
& engine I just done is a 1989 998 with press fit
Posted 20 December 2014 - 12:20 PM
DONT use jonspeed!! Very bad reviews
Care to elaborate? Where can I read these?
I know this link birtngs up cylinder heads, but its the easier parts to do on an engine...
http://www.theminifo...ed#entry3168239
Posted 20 December 2014 - 01:32 PM
Or heat the small end evenly and slowly until it goes blue or burns off carbon deposits and the pin should slide striaght in, hold the pin and piston steady and swing the rod until it grips the pin then keep swinging the rod for about 15 seconds and make sure it's still nice and free in the piston once it's fully cooled and work lots of oil into the relief in the skirt for the pin for initial start up lubrication
Heat shrinking the pins into the rods makes it very hard to test the fit as you do it. There is no way to test the force required to break the joint if it just drops in. As said above with a press you can monitor the load on the pin as it slides in and look for any free spots. The Rover way to change them is with a threaded press tool using a torque wrench to deliver at least a specific minimum load to the pin as it slips through.
Mini Spares used to have teflon buttons in the catalogue, they seem to have disappeared. Presumably due to the difference in the available pin diameters as said above.
Edited by Dan, 20 December 2014 - 01:33 PM.
Posted 20 December 2014 - 02:08 PM
Posted 20 December 2014 - 05:30 PM
Posted 20 December 2014 - 06:02 PM
