hi would like to fit mk2 rear lights in my 92 mayfair as i intend to fit a lucus rear mounted reverse light on the boot if i can find one that is can i just change the lenses and just dissconect the reverse lights or do the whole lights need to be changed and if so is the wirering different or is it just plug and play
Fitting Mk 2 Rear Lights In A Later Mini 92 Mayfair
asterx0
, Dec 28 2014 11:25 AM
electrical
2 replies to this topic
Posted 28 December 2014 - 11:25 AM
Posted 28 December 2014 - 11:27 AM
I believe the light unit is different. The ones I have don't have the same multi plug connection either
Posted 28 December 2014 - 11:33 AM
As above the unit is different, I think someone has swappd just the lenses but needed some cutting. This thread will help if you change the whole units, but to do this you'll need to move the petrol tank to get to the nuts. http://www.theminifo...ght-conversion/
Another way of doing it is to tint the bottom of the mk4's to make them look like the mk2's.
Mini Technical Sections →
Problems, Questions and Technical →
Trying To Find The Right Wire Harness Online...Started by mattaebersold , 22 Jul 2025 ![]() |
Mini Rio 93 Boot Wiring IdentificationStarted by KanKanManKan , 11 Jul 2025 ![]() |
Rebuilt Engine Wont Crank With CompressionStarted by Kernreuben , 04 Jul 2025 ![]() |
1987 Mini Rover Fuel Gauge IssueStarted by kwfranky , 11 Jun 2025 ![]() |
![]() 1986 Mini Chelsea - Main Beam IssueStarted by Dominic1998 , 25 Apr 2025 ![]() |
