Posted 06 January 2015 - 08:10 AM
I removed the plugs to find three of them wet with water. I fed rolled up tissue in to the four spark plug holes and three were wet with clear clean water. Cylinders 1,2 and 3 had water in them.
The car had been running hot and overheated before fitting new radiator but there was no water in the cylinders.
I find it very strange that a blown gasket can affect 3 cylinders. I would be very grateful for your opinions.
Thanks.
Posted 06 January 2015 - 08:50 AM
To add to this if the engine got really hot when it overheated it may possibly have warped the head. Once the head is off you can check for face trueness with a large steel rule.
Posted 06 January 2015 - 09:00 AM
Wip the head off, inspect gasket, check head it straight, then clean it all up, fit new gasket and gradually torque head down to 50lbf using the correct order in the manual, then warm it up and go to 60lbf.
If you aren't sure or need help, shout.
Posted 06 January 2015 - 09:09 AM
It's not un heard of to be honest. Has the head been off recently?? Did it get retorqued correctly after one heat cycle.
Thanks for that. The head gasket was replaced a year ago due to fitting new valve guides but I didn't retorque it after one heat cycle.
Posted 06 January 2015 - 09:11 AM
Thanks for that. I will refit a new gasket, check the head and retorque after warming it up.As above, the damage has most likely been caused by the overheating.
Edited by minitalia1275, 06 January 2015 - 09:23 AM.
Posted 06 January 2015 - 09:47 AM
Not everyone retorques the head, some say yes some say no and get away with it for years.
Personally I think when a headgasket is going to blow it will anyway because of other factors outside of normal working pressures.
At least its one of the easier jobs to do on a Mini.
Edited by Gadgets, 06 January 2015 - 09:47 AM.
Posted 06 January 2015 - 09:56 AM
Without getting into a slanging match this is a gamble that to be honest is not worth thinking about. It's like most things if you don't follow the maintenance laid out by the manufacturers no matter what it is then you are gambling. Is it worth it, in my eyes no it's not.
Changing the HG is a easy job IF you know how to do it and of course have the tools available. Also another thing to consider is the quality of the head gaskets out there. I had an issue with a standard copper head gasket last year that would not seal properly. It did do the L2B run ok but kept leaking fluids externally which is not good. A Payen HG cured that issue.
So from a personal point of view and being an Aircraft engineer for the past 35 years follow the manual, deviate from it at your peril. And I'm not just talking about Haynes, I'm talking about any manual for your car.
Posted 06 January 2015 - 09:57 AM
Fair point, but if you are already on it, I can't see why you wouldn't.
As a complete aside, can I see a pic of your van with the D1s please?
Posted 06 January 2015 - 03:38 PM
I think the problem was caused by the overheating and the budget minispares gasket fitted. I will replace it with a good quality Payen gasket
Posted 06 January 2015 - 05:03 PM
Posted 06 January 2015 - 05:45 PM
Posted 06 January 2015 - 05:55 PM
Stick a copper or Payen gasket on and torque it down after hot.
Posted 06 January 2015 - 06:02 PM
Seen worse!
Posted 11 January 2015 - 02:06 PM
Hi
I have since lowered the front hi los's and rear coil overs, wheelarch gaps are now alot closer.
Edited by Gadgets, 11 January 2015 - 02:18 PM.
#15
Posted 11 January 2015 - 02:21 PM
Yes interestingly I know a Rolls Royce Aerospace trained mechanic employee and he also dosnt retorque Mini heads after replacing head gaskets and he always says he has never had one fail.
Rebuilt Engine Wont Crank With CompressionStarted by Kernreuben , Yesterday, 01:59 AM ![]() |
