Nuts N Bolts
41 replies to this topic
#16 benm
benm
  • 111 posts
Posted 06 January 2015 - 09:33 PM
what annoys me is some things are metric, and then some are bloody imperial!!!!!!!
oh ill just replace that rusty looking m6, ohh wait ,its a darn 1/4
#17 MrBounce
MrBounce
  • 2,659 posts
Posted 06 January 2015 - 10:21 PM
I'm very lucky in that there's a very useful family run shop on an industrial estate near where I work. http://www.suffolkfasteners.com/ Don't think they do mail order though.
I don't know much about bolts, set screws etc, but I have several unusual bolts that hold the rear beam on to the Midas, and they REALLY need replacing. I needed 12 strange sized bolts, with appropriate nylocs and washers. It was no problem for them and only cost about £8. They're also happy to do "one-offs" over the counter - even for single items.
Can't recommend them enough :thumbsup:
#18 Bubblebobble
Bubblebobble
  • 661 posts
Posted 06 January 2015 - 10:29 PM
I used to use Oxford Seals And Bearings in Bicester . Any amount of anything , in any material or hardness  excellent service .
#19 nicklouse
  • 18,657 posts
Posted 06 January 2015 - 10:34 PM
Sounds just like who I used to use back in Huddersfield. Danlett you want it they have it. But no website.
#20 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 06 January 2015 - 10:46 PM
I have my own supply!
http://www.britishnutsandbolts.se
#21 nicklouse
  • 18,657 posts
Posted 06 January 2015 - 10:58 PM
Not surprising. With all the Yank tanks in Sweden.
Not sure that my mate Craig is aware of them though.
#22 Spider
  • 15,043 posts
Posted 07 January 2015 - 06:29 AM
And what's a useful range of imperial threads - UNF or UNC?
On your second question, in regards to a Mini, you'll go through far more UNF fasteners than UNC.
UNC are generally (but not exculsively) used where a fastener screws in to a casting, eg, Thermostat Housing Threads are UNC. Just about all others are UNF.
#23 fenghuang
fenghuang
  • 796 posts
Posted 07 January 2015 - 08:15 AM
Purists would hate me but I use the dreaded metric better range high tensile standard 8.8 (S equivalent) you can get higher grade 10.9 and 12.9. Secondly most sizes are available in multi grade SS as well.
They are also much cheaper !
Can you elaborate on tensile standards, and what is most likely to be useful for a mixed Mini bag? (I'm not a purist and I don't like spending money unnecessarily, so metric is fine by me.)
Am I right in thinking those will invariably be hex head?
#24 frobnitzz
frobnitzz
  • Just Joined
  • 100 posts
Posted 07 January 2015 - 09:01 AM
The mixed bags seem a good idea, I wish I'd seen this at the start of my rebuilt to be honest! Then again, I only seem to be able to properly identify a fine/course and size by using known nuts (as in ones from minispares I know are xyz size so will fit on the bolt)... so the idea of trying to filter 450 bolts... haha!
#25 frobnitzz
frobnitzz
  • Just Joined
  • 100 posts
Posted 07 January 2015 - 09:05 AM
I'm no purist either! see left!
mmm socket cap head screws *drool*  :proud:
#26 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 07 January 2015 - 09:28 AM
I used to get free AN bolts from work and use them where suitable. Imperial thread, aircraft grade bolts. :teehee:
#27 mikep12
mikep12
  • 73 posts
Posted 07 January 2015 - 10:33 AM
Very few applications on a mini would require anything other than 8.8 but as I farm I use a lot for other applications where higher strength or hardness is required for example in applications that have severe operating conditions such as flail mowers and hedgecutters you need a very toughbolt or where you really never want to change a bolt again.
I think the only place you would use different would be bottom end and clutch but these are already higher spec. Don't ever bother with crap such as 'aircraft grade' as this only means you get the same bolt for a higher price but with a much higher run sampling rate.
#28 Dusky
Dusky
  • 5,322 posts
Posted 07 January 2015 - 11:06 PM
And I live in Belgium, cant find a store within 50 miles that stocks imperial..always order them on the bay now..:P
#29 Spider
  • 15,043 posts
Posted 08 January 2015 - 07:18 AM
Before we start getting down to specifics on fasteners, what's your intended project?  I'm guessing it something to do with a Mini (of course!), but some custom work, total top to tail rebuild, front subframes, engine build????
#30 ROD
ROD
  • 2,215 posts
  • Local Club: MCR
Posted 08 January 2015 - 04:21 PM
They are handy to know about, plus they are not too far away.
