Got a bit done over this weekend - the rear valence is sealed and painted, so now the closing panel can go in, and thats the last panelto be welded in.
Scrubbed up some of my suspension bits n bobs - adjustable tie bars, bottom arms and hi-los. Typically the front minisport hilos that I bought from Alburglar are different to the rear ones, so the new knuckle joints I bought dont fit. Minisport will be getting an angry phone call tomorrow then....
After getting fed up with forgetting to take the cone compressor with me so I could finish getting the bottom arms off, I took the "Jeremy Clarkson" approach and just chopped the subframe towers off. Not to be recommended if you plan on reusing the subframe. When I got the arms out, one is in perfect condition, while the other is utterly fubared. How typical!
