Fitting Distibutor
electrical
3 replies to this topic
#1 tefer
tefer
    Just On Tickover
  • 8 posts
Posted 30 March 2015 - 04:58 PM
Hi peeps I'm having problem refitting the dizzy it doesn't seem to go in far enough there's a gap between base plate and bolt holes. Hope someone kind can help me please.
#2 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 30 March 2015 - 05:21 PM
Is the slotted end lined up properly? It might be 180 degrees out.
If you need to remove and turn the dizzy drive that runs off the cam make sure you use a bolt or stud to remove it as it will fall into the gearbox - mine did years ago.
Hope this helps.
Ian
#3 tefer
tefer
    Just On Tickover
  • 8 posts
Posted 30 March 2015 - 07:21 PM
Thanks Ian will have a fiddle tomorrow. Another problem do you no where I can get the weld in seat bar mounts for my reclining seats then if I'm right my runners then bolt onto them. Can't you tell I'm new to this many thanks again
#4 59 Speed
59 Speed
  • 674 posts
Posted 31 March 2015 - 07:00 PM
Not 100% sure on what you mean but came across these, any good?
http://www.motorspor...-rally-car.html
I would have a go at making some first though if you have the tools.
Edited by Smackfiend, 31 March 2015 - 07:01 PM.
