Hi all, I'm hoping for some advice. I recently put a new 075 battery in my 86 Mayfair 998 and later realised (when I lost all forms of power whilst driving!! ) that I had not connected the negative battery terminal correctly and it disconnected
. After re-connecting the battery properly and starting him up, the red warning light on the dash, which I believe indicates that the battery is not charging, now stays illuminated all of the time. I'm wondering that if the battery coming undone whilst the car was on and in motion has done some damage or if the warning light is just throwing a wobbler??? Any suggestions would be gratefully received, cheers.
Battery Came Loose, Reffitted, Now Charge Light Wont Go Off!
Best Answer New game mini , 05 April 2015 - 08:03 AM
Oh bum, thanks for your replies!
Go to the full post
Posted 04 April 2015 - 08:14 PM
Posted 04 April 2015 - 08:58 PM
Sorry to be the bearer of bad news, but when the bettery terminal came off the alternator spiked up in the 200v + range and its taken out the diode pack in the alternator, the red ignition light is indeed on because its not charging, its either a replacement Alternator or replace the diode pack if you have a soldering iron and a manual
Posted 04 April 2015 - 09:03 PM
Kernowcooper will have the answer. Edit: he has the answer
Edited by Richie83, 04 April 2015 - 09:04 PM.
Posted 05 April 2015 - 08:03 AM Best Answer
Mini Technical Sections →
Problems, Questions and Technical →
Trying To Find The Right Wire Harness Online...Started by mattaebersold , 22 Jul 2025 ![]() |
Mini Rio 93 Boot Wiring IdentificationStarted by KanKanManKan , 11 Jul 2025 ![]() |
Rebuilt Engine Wont Crank With CompressionStarted by Kernreuben , 04 Jul 2025 ![]() |
1987 Mini Rover Fuel Gauge IssueStarted by kwfranky , 11 Jun 2025 ![]() |
![]() 1986 Mini Chelsea - Main Beam IssueStarted by Dominic1998 , 25 Apr 2025 ![]() |
