1989 Mayfair Project
49 replies to this topic
#46 Mito
Mito
  • 458 posts
Posted 29 March 2026 - 04:52 PM
New bungs fitted to all of the holes in the floor and epoxy primed
Attached File  1000026283.jpg   50.08K   0 downloads
Replaced the battery negative terminal.
Attached File  1000026071.jpg   26.75K   0 downloads
Replaced the fuel tank bracket
Attached File  1000026068.jpg   35.18K   2 downloads
Spent some time setting up a new air line in the garage
Attached File  1000034982.jpg   56.9K   2 downloads
Pressure tested over night to 300 psi, using water of course.
Attached File  1000034978.jpg   38.5K   2 downloads
Patched up the n/s rear arch
Attached File  PXL_20260323_165233685.jpg   51.71K   0 downloads
Attached File  PXL_20260323_165230691.MP.jpg   52.23K   0 downloads
Attached File  PXL_20260323_165226476.MP.jpg   57.93K   0 downloads
Attached File  PXL_20260323_165300176.jpg   63.77K   0 downloads
Attached File  PXL_20260323_165254936.MP.jpg   66.97K   1 downloads
Attached File  PXL_20260323_165248855.jpg   37.52K   0 downloads
After this, I discovered that the top part of the arch is heavily pitted, so this will be fully replaced.
Repaired the top section of the o/s rear quarted panel.
Attached File  PXL_20260323_165314458.MP.jpg   47.16K   0 downloads
Removed the old wax oil from the floor.
Attached File  PXL_20260323_165341927.MP.jpg   62.02K   0 downloads
I found there's some further areas of the boot floor requiring attention and a small piece of the drip rail. As well as the rear arch replacement. I'll work through these next and strip the paint off of some other areas to ensure there's no rust lurking in them.
#47 stuart bowes
stuart bowes
  • 2,609 posts
Posted 31 March 2026 - 11:12 AM
whats the logic with the copper pipe going up and down along the wall ?  just curious what that's for really I'm sure you have a reason
#48 sonscar
sonscar
  • 3,241 posts
Posted 31 March 2026 - 12:01 PM
Water removal from cooling the air,I have similar and regularly drained it works.Steve..
#49 stuart bowes
stuart bowes
  • 2,609 posts
Posted 31 March 2026 - 12:53 PM
ah ok so they're water traps then, fair do's, we dont have any hard lines, just the flexi hoses straight from the tank which has a water release key on the bottom
#50 Mito
Mito
  • 458 posts
Posted 31 March 2026 - 07:41 PM
I only had an 8mm hose running along the floor before I set this up which just got in the way and it was only a matter of time before I hit it with some molten metal :). I'll see how well it works over the coming weeks as I have some touching up to do on the other mini
Edited by Mito, 31 March 2026 - 07:42 PM.
